OMR: '76 KZ900 Restoration/Modification
  • PLUMMEN
  • PLUMMEN's Avatar
Re: OMR: '76 KZ900 Restoration/Modification
04 Jan 2009 08:31
#256087
that sure is a purdy tape measure ya got there!:laugh:
  • trianglelaguna
  • trianglelaguna's Avatar
04 Jan 2009 09:05
#256092
great thread...on the favorites list....thanks alot for each picture and how your theory is along each photo...even i'm starting to get what's happening there..takes some of the mystery out of what i may need for my head ... and i may have some questions ...before i re-assemble the 73 motor.....thanks again..peace
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Jan 2009 09:54
#256263
Glad to here everything is coming together for you.
Regarding MRE, look on the bright side. You learned a lot from this , as far as engine building goes. It really is a good thing that the piston hit the head. Just think of what would have happened it just cleared. The most important lesson I learned, was to measure EVERYTHING. As soon as u get away from stock and start your own build u have to record every measurement there is.
This is how I discovered that my professionally built motor had a poorly aligned machine surface on the block and case, resulting in #1 piston being .007” higher than #4.
Its all good bro.
We all just keep learning.
B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
05 Jan 2009 10:35
#256272
Amen to that brother....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
08 Jan 2009 03:28
#256678
Just a little update....
Based on Larry's advice (thanks Larry) the ideal shim clearance desired would be .04 to .06...
Received my new 2.4mm shims from Z1....
I installed the new 240's on the Intake side and swapped 235's into the exhaust side. My new measurements are as followed.
Valve Lifter Clearance:
Intake # 1 # 2 # 3 # 4
.05mm .04mm .05mm .05mm
Exhaust # 1 # 2 # 3 # 4
.05mm .05mm .05mm .05mm
For good measures, I went through the cam degreeing triple checking everything was in order... good thing I did.
My intake came out at 105.75 degrees, no adjustments where required for the lobe center of my .365 cams are 105.
But my exhaust side was way low ~ 80 degrees.... Hmmm, this was somewhat odd to me, should have been closer to the 105 setting I had left it at.... It was as though I had originally been turning it the wrong way (slotted sprockets)
Anyhow, readjusted and came out at 105.5 degrees....
I'll probably go through it one more time tonight for assurance, not to mention I'm being a pussy about it, lol!
All is good where I can finally get this going....
Found locally Kreme's Blue coat for the inside of the Kerker header.... Coat the internal header for anti bluing... I'll keep all posted if the shit truly works... Kinda spendy stuff ~$30!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
08 Jan 2009 03:39
#256679
Before firing up this old girl, had to get the Kerker mounting brackets fabbed up so in this image, just on there to see how she'd look....
We,ll got pretty excited so bolted on some other stuff for a teaser...
Still have the following to complete:
Kerker mounting bracket.
Possible Carb jetting (Kerker 1.5" baffle) & tuning.
Acewell 4000 Digital speedo/tach, June.
Electronic Ignition timing adjustment (timing light).
New tires.
LED turn signal mirrors.
Oh yeah, almost forgot... Küryakyn™ Footpegs for the wifey poo!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • JohNLA
  • JohNLA's Avatar
08 Jan 2009 12:35
#256731
It's not shiny enough yet;)
Wow!!! I have waited so long to see it all together. Words can not express my joy:blush:
You are probably pretty excited, as well.
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
  • PLUMMEN
  • PLUMMEN's Avatar
08 Jan 2009 15:18
#256758
New tires.
OMR
might i suggest that you also finish painting the frame? :whistle::laugh:
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
08 Jan 2009 18:36
#256830
i could spend hrs looking at your bike!
awesome job!
  • keith1
  • keith1's Avatar
08 Jan 2009 18:58
#256835
kick-ass job....looks great.....cant wait to see the vid of you riding it.....keith
  • Zedone
  • Zedone's Avatar
08 Jan 2009 19:39
#256845
Looking awesome OMR.
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • Kawozaki
  • Kawozaki's Avatar
09 Jan 2009 19:47
#257032
G'damn! That's pure sex.
