Building a GPZ1150 from a CSR1000
- otakar
Re: Building a GPZ1100 from a CSR1000
31 Mar 2010 11:49
porchev914 wrote:
That fuse block came from Del City. They have a $25 minimum order so you have to order a few of them. I ordered four so I would have a few spares. If you don't want to spend $25 + postage send me an email at otto@condormodels.com I can part with one.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- trianglelaguna
Re: Building a GPZ1150 from a CSR1000
31 Mar 2010 11:50
sweet..great pics...nice upgrade...very nice
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- otakar
31 Mar 2010 12:07
It is still a work in progress. I want to have everything done this spring though.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- porchev914
01 Apr 2010 12:49
Delcity has a lot of handy products for wiring projects like our bikes!
FRANKEN Z!
- otakar
01 Apr 2010 14:22
just taking a little brake. I am in the process of converting to a 530 chain from a 630. Everything went fine with the exception that the front sprocket has no holes to use the bolt lock. I hope that the sprocket bolt holds.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- porchev914
01 Apr 2010 16:01
You might go through a few drill bits on the sprocket, but you could drill holes in the head of the bolt and the sprocket and safety wire it. At least that way you can have some piece of mind
FRANKEN Z!
- otakar
01 Apr 2010 17:10
I attempted that, I even used a carbide drill bit. It won't even faze the sprocket.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- porchev914
01 Apr 2010 17:21
Do you still have the splined washer for the c.s. sprocket bolt? You could drill a hole in that and use it to wire to, or bend it over the bolt like OEM. You'll have to forgive the suggestions, I'm sure you have already though of all these solutions
FRANKEN Z!
- otakar
01 Apr 2010 17:43
this is a J series motor the locking system is completely different from th earlier engines.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- testarossa
01 Apr 2010 17:57
otakar wrote:
What did you use to spin that carbide drill bit? Was it a hand drill or a drill press? Also what size drill bit where you using?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
01 Apr 2010 18:02
otakar wrote:
That COMPLETELY explains my ignorance :laugh: Testerossa my be able to help better, he lives in a machine shopthis is a J series motor the locking system is completely different from th earlier engines.
FRANKEN Z!
- otakar
01 Apr 2010 18:57
This was done in a drill press and I tried three different sizes starting with 1/8 and went up.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
