Building a GPZ1150 from a CSR1000
  • otakar
  • otakar's Avatar Topic Author
08 Sep 2007 19:14 - 01 Nov 2009 14:34
#169462
I thought I would shair this with you guys. I bought a 81 CSR from a friend of mine. Since I do NOT like the crusers I thought I would be different and make something more interresting to me. A GPZ1?00. Wel the initial investment for the bike was $1600 tan came all the ebay parts.
Well here goes Head light, Headlight mounts, Front forks, Front brakes, Master Cylinder (new), GS1100 Swingarm, New Avon Venom tyers, GPZ seat, GPZ Tank, GPZ Sidecovers, Mikuni 33mm Smooth boars, New Paint job, two rims, KZ1300 Rear axel, KZ900 gront axel, New turn signals, Front fairing, Front fender, Oil cooler, New low bars, ALL New cables, New gripps, New windshield, 1984 gpz instrument cluster New custom built Tytanium shifter lever, KZ1300 rear brake pedal, Wisco 1166 kit, MAC Pipe, New Progressive 14" rear shocks, PLUS a ton of miscelenious hardware etc.etc. And I am sure I have forgotten a lot.
:woohoo: :woohoo: I have not yet installed all the parts but IT IS A START.
Post edited by: otakar, at: 2007/09/08 22:20
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 01 Nov 2009 14:34 by otakar.
  • otakar
Re: Building a GPZ1100 from a CSR1000
08 Sep 2007 19:24
#169463
It will be noticed what has already been done. I still have a way to go.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
08 Sep 2007 19:37
#169465
Here is the work on the tank. The stripper used was bought at a PPG dealer and is an aircraft grade.
Post edited by: otakar, at: 2007/09/08 23:06
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
08 Sep 2007 19:39
#169466
Stripped to clean metal
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
08 Sep 2007 19:40 - 08 Feb 2009 09:25
#169467
Dents first pulled out and than filled using "Metal to Metal" filler by "Evercoat"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 Feb 2009 09:25 by otakar.
  • otakar
08 Sep 2007 19:41
#169468
Featherfill applied for finel sanding before putting on DPLF primer.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
08 Sep 2007 19:43
#169470
Setting back the foot peg and installing a KZ1300 Brake lever.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
08 Sep 2007 19:44
#169473
Good view of the GS1100 swingarm installation and the 16" LTD rim.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
08 Sep 2007 19:49
#169475
The front fender, Fairing, sidecovers and tail piece, I painted with PPG DBC/DBU and 2002 clear coat. The color I had mixed to match the oryginal bike color in which I bought it. The Trim stripes I mixed myself and are a dark purplish red and a Tytanium silver with a touch of red tint.
Post edited by: otakar, at: 2007/09/08 23:09
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
08 Sep 2007 19:54
#169477
All of the sidecovers will be "Gun-coated" gloss black as you may have noticed a few have already been. I have baught spair engine covers and have finished all but the alternator cover. I have also decided to install Brakes from a 86 GPZ in front. (Not yet finished rebuilding them) Also you may have noticed the GPZ front forks. The front tyre is undersized it is only a 100 and not a 110 on a 19" rim.
Post edited by: otakar, at: 2007/09/08 22:57
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
09 Sep 2007 02:03
#169530
I'm impressed...keep posting pictures as this transformation is pretty interesting.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • otakar
09 Sep 2007 06:45
#169549
Here is a shot of the Tytanium shifter, the "Guncoated countershaft sprocket cover, and the left rearset.
Post edited by: otakar, at: 2007/09/09 09:47
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
