Building a GPZ1150 from a CSR1000
- SLEEPER650
Re: Building a GPZ1100 from a CSR1000
18 Nov 2007 10:13
How much would you charge to do a set of 28mm pumper carbs in the chrome
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- otakar
18 Nov 2007 11:59
If you are reffering to clearcoating polished Aluminum with Gunkote. The bigest expense is the polishing of the parts. The clearcoating of the eight parts (Boles & Domes)would be $50. Polishing of the parts would be about half hour each. You would be looking at about four hours of polishing for the eight parts. The parts must not be polished to a mirror finish because the gunkote neads the fine scratches to stick to.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Oldhemi
18 Nov 2007 13:31
I will take the seat with much appreciation. I will send you KZrider email with the particulars.
Thanks very much.
PS. Its the seat in the very 1t pic/post,right?
Thanks very much.
- otakar
18 Nov 2007 15:54
I should get rid of all of the spare parts from the CSR. anyone who is reading this Forum. here is a partial list, at least the parts I can think of.
Fuel tank (no emblems no fuel float or petcock.)
Side covers (with emblems)
Front forks (no Trip tree)
Oryginal coils
Headlight with mount
Front brake master cylinder.
Spoke wheels 2 F & R
Air Box with boots
Brake pedal
Rear tail light
Swing arm
Rear Shocks
That is what I can think of at the moment. I have not thought of selling the parts before now so no ferm prices have been astablished. No REASONABLE offer will be refused
Post edited by: otakar, at: 2007/11/18 18:56
Post edited by: otakar, at: 2007/11/21 16:20
Oryginal coils
Air Box with boots
Brake pedal
Rear tail light
Swing arm
Rear Shocks
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- NightScreams
21 Nov 2007 11:34
You work is stunning, what a cool project!! Thanks for sharing it with us...and thanks for serving, Otakar
- otakar
02 Dec 2007 08:22
For the last few weeks I have been wrestling with a dilemma. I want to mount a oil cooler on the bike but it is very hard to find any kind of clean provisions to mount the oil lines onto the crank case. So, I decided to make my own. Here is a new oil pressure oil Bypass unit, modified to mount 3/8" compression fitting, solid Aluminum oil lines.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
02 Dec 2007 08:25
View from other side. I also decided to make provisions for a oil pressure gauge while I was at it. The unit is a modified stock "J" series oil bypass with aluminum elbow added for return and Stainless 3/8" tubing fittings.
Post edited by: otakar, at: 2007/12/02 11:26
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
02 Dec 2007 15:54
Nice looking work there otakar, as usual.hears a good project to look at.
kzrider.com/component/option,com_joomlab...mit,20/limitstart,0/
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Kaw
- Flying Squirell
02 Dec 2007 21:00
Ha! You read my mind, Mark! That's exactly what I was thinking.
I wonder if we got tuxedotito and this guy together if it'd be like introducing the "Keymaster" to the "Gatekeeper"!? :woohoo:
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- otakar
03 Dec 2007 16:13
Since I am punching the engine to a 1170 I plan on using a larger oil cooler than the standard GPZ came with. I also plan on using solid Aluminum 3/8 oil lines which also will dissipate heat quite efficiently. I plan on running the lines over the top of the engine, to hide them as much as possible.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Dec 2007 19:55
Well guys, Santa was nice to me and got me a REAL Xenon headlight conversion kit. WOW, a 100 Watts of light from 35 Watts of juice. I have also finally finished my new instrument cluster, retrofitting ALL light with LEDs. The entire cluster now only draws 25 Mili-Amps. I will post a picture tomorrow. I will also use LED bulbs on all of my turn signals and tail light.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
29 Dec 2007 13:42
do those thinks realy work as well as that.u will have to let us know.
Is there a gun coat in a black that looks like the stock engine color, more of a satin than a gloss??
Where is the best place to order from?
Post edited by: mark1122, at: 2007/12/29 16:44
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
