Building a GPZ1150 from a CSR1000
  • otakar
  • otakar's Avatar Topic Author
Re: Building a GPZ1100 from a CSR1000
01 Feb 2008 05:04
#192164
The CSR is a "J" motor. It is Identical except the bore, cams, and color to the GPZ. The GPZ also had the Fuel Injection. Otherwise all the parts are interchangeable. And YES I am keeping the 16" rear rim. I intentionally put it on the bike from a LTD eBay auction. The basic configuration of cosmetics and geometry the bike is as it will be. The engine is the only undecided. I did find out from MTC that the "J" block is a bit thicker than the pre-81 blocks and will accept sleeves for a 1261 kit without windowing threw anywhere, and still leave me .1" of sleeve thickness. I think that this is the route I will go. I know when boring a stock sleeve on a kz1000(1015) to a 1103 there is only.06" sleeve thickness on sleeve wall. But this may change again and I may finally settle on the 1197. Most likely because I have two if these kits just sitting around, if for no other reason besides, the one that I will save $700.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
01 Feb 2008 17:25
#192278
Sorry about the confusion. i didnt know that the csr was the same as the j. it sound like u have it all figured out. i like the 1200 idea. are the pistons 14:1?
Thanks Steel.
Post edited by: mark1122, at: 2008/02/01 20:32
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • N0NB
  • N0NB's Avatar
  • Blue handles better
12 Feb 2008 05:06
#194168
That's an amazing project!
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • otakar
12 Feb 2008 05:30
#194170
Thank You
The only thing which I could not make my mind about was, what size motor to build. Wel, I made the decision to build two motors. One 1135 for everyday riding and a 1200 for when the erge hits me. Delema fixed.:silly: :whistle:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
28 Feb 2008 16:44
#197427
Well, I started working on the head. I did mention that I found a 84 GPz1100 head. I finally got some work finished. First I stripped it down to clean metal. I did a new valve job. I matched the boots to the intake ports and got the porting and polishing almost finished. Valves are NEW and ground. I have some 435 lift cams with 288 duration. I will post some pictures of the head tomorrow.
Post edited by: otakar, at: 2008/02/28 19:46
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
29 Feb 2008 01:03
#197474
I have a spare J block off GPz1100. The sleeves are larger to start with so you can make a larger bore than the 998 J block. It is presently stock but because of scoring needs 1/2mm taken out. Send me a PM and maybe we can swap some parts. My parts are in GA. I'm in HI until mid March.
-Duck
  • otakar
29 Feb 2008 08:05
#197512
Hay Duck, I'm jelous! I consider HI as my second home. I was stationed there 3 times over the years for a total of 10 years. My first two bikes came from Cycle City. The best ride in the USofA is up or down the Kole-Kole Pass from the naval amunition dump to Scofield Baracs. I like the doward run the best, which is the other way around:woohoo: :woohoo: :woohoo: I had a friend in Hawaii who was also from Atlanta He was a GS750 rider at the time and ran the Suzuki dealership in Kaneohe. His name was Don Wilson.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Duck
  • Duck's Avatar
29 Feb 2008 09:56
#197528
It's a second home for me too. Spouse Linda works at UH Manoa since 2000. No bike here. No place to park or work on it. I like old bikes and they always need work :-0 Maybe next year. With the new ferry it will be easy to do some riding on Hawaii and Maui.
  • otakar
29 Feb 2008 10:24
#197540
Here you go Duck. 1978 K-Bay If you don't have a bike in HI you are missing the riding of your life.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
29 Feb 2008 17:02
#197602
Oh man, if you make it to Maui take the road to Hana (Hannah???...dunno how to spell it, just know it's cool). 52 miles of ocean-front/cliff-side riding; take you 2 hours...4 if you stop for photos (like the dork tourists we were:whistle: )...you'll never get out of 3rd gear...maybe not second! Can't wait to go back.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • otakar
01 Mar 2008 13:40
#197770
Here are the pictures of my partly ported head. The intakes are finished but I must still finish the ehaust side. I plan on taking the head into a speed shop and have it flow tested.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
01 Mar 2008 13:42
#197772
I use media blasting as little as possible. I have a propriatery Chemical cleaning process which removes all the crud and will not harm the Aluminum.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
