Building a GPZ1150 from a CSR1000
  • otakar
  • otakar's Avatar Topic Author
Re: Building a GPZ1100 from a CSR1000
11 Sep 2007 05:23
#169962
Gringo
I Forgot to mention something about Gun-Kote; Once it is on the only way to remove it is by sanding or sand-blasting. There is no paint stripper on Earth which will touch it. This includes soaking it in DOT-3 brake fluid for 6 months.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
11 Sep 2007 05:37
#169965
Thanks alot for the info on this Otto. I googled them and found out this stuff is available in a spray can, a little pricey at $29 a can but I suppose it will go a long way. The upside is that once done it looks like it is almost zero maintainence. How have you been prepping say your engine covers prior to coating them?
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • otakar
11 Sep 2007 10:55
#170001
If you plan on useing a pigmented coating. I media blast first, than I do a 30 second soaking in a 25%soluttion of Hydrochloric acid. Than wrince with regular water, than quickly with distilled water to prevent corrossion. Blow dry, than wash off with Butyl Alcohol (very important) do not use other alcohols because they will corode the metal immediately and atract moisture. Than I do a cold Pfosphatting treatment with K-Phos. After this I bake for 1 hour at 125*f Than Spray. Now you dry for .5 to 1 Hr at 125f than bake for exactly 45min. at 325f. Do not go past 330f or much over the 45min. because the color may change and clear will yellow. If you plan on doing a polished surface, do NOT polish to a mirror finish, and skip the Phosphating procedure, follow everything els in the same order. The finish is not as durable but still better than no finish at all.
Otto
Post edited by: otakar, at: 2007/09/11 17:02
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
11 Sep 2007 12:09
#170013
I like this a lot, look forward to seeing the finished project!
I'm doing something similar with my LTD750...
Post edited by: guitargeek, at: 2007/09/11 15:13
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • otakar
14 Sep 2007 17:22
#170615
Would one of the moderators be so kind and move this thread to the "PROJECTS" section I somehow screwed up and put it where it do not belong.
Thank You
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
15 Sep 2007 10:26
#170725
Well; I caused a major desaster! Yesterday, I started to paint my gas tank. After the featherfill I smooth sanded the tank and shot it with DP-LF red primer in the morning. At about four o'clock I started to paint the stripes (which I always paint first). Fore some reason, which i just could not place my finger on, the paint just wasent acting right. It was too glossy, it wasent drying right and soforth. At about 2100 hours, I was ready to paint the main color. While mixing it I just realized that I have added "Hi-Solids hardner to the base cote instead of base cote activator. Well that just explained why the other colors wernt performing propperly. Well, this morning I started to sand and wash off my screwup from yesterday. Well, i'ts 1230 hours and I am at the same place I was yesterday at about 1630. What a waste of time and material. As the lovely Dorris Day used to say "Que Sera Sera"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
16 Sep 2007 06:46
#170871
After a lot of extra work I finished the tank, well- almost finished. Here are some pictures and the runn-down. This is the tank with final DP-LF E-poxy primer before the screwup.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
16 Sep 2007 06:49
#170872
Here is another before the mess-up. The DP-LF Epoxy Primer is one of if not thee best primer I know of. It can be used under anything EXCEPT Lacquer.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
16 Sep 2007 06:50
#170874
After the screw-up was fixed, here is the tank with the stripe colors back on (with the right activator this time)
Post edited by: otakar, at: 2007/09/16 10:10
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
16 Sep 2007 06:52
#170877
Fore those who are not familiar with Base/Clear formats, the base collor dries low-gloss.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
16 Sep 2007 06:54
#170878
Well we are getting there. About 9 work hours later than I wanted to but still getting there.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
16 Sep 2007 06:55
#170879
On these pictures it is realy noticable how low gloss the paint is.
Post edited by: otakar, at: 2007/09/16 09:59
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
