Mikuni VM 33 Carbs
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Mikuni VM 33 Carbs
28 Jan 2019 07:10
#797750
Look'n good Steve. Ride the peace out of it brother! B)
1982 KZ1100-A2/1170cc sleeper 😀
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
28 Jan 2019 07:13
#797751
With a little help from my friends. B)
  • SWest
  • 10 22 2014
13 Feb 2019 06:49 - 13 Feb 2019 06:50
#798588
Gotta dial in the pilots again this morning. Looks like rain this evening, off and on the rest of the week. At least I'll be able to test ride it today. B)
Last edit: 13 Feb 2019 06:50 by SWest. Reason: sp
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
13 Feb 2019 10:31
#798602
Could the soot on the spark plug base rings be oil residue?
My plugs have that too, and the insulator and electrodes look nearly as good as yours.
Last check I'm adding oil more often than I like, which may indicate the source of the base-ring carbon on my plugs. I have about 20K miles on this set of OEM Kaw rings installed in 2015.
I usually ride in the upper safe RPM range, which in my mind may account for additional piston ring wear if compared to a similar engine run consistently at lower engine revs.
Installed new Viton valve seals in 2015, but I wonder if they may not work as effectively since the cams were changed from standard to ZX at that time, but the 8K mile original valves were just checked and reused.
:huh:
  • SWest
  • 10 22 2014
13 Feb 2019 20:34 - 13 Feb 2019 20:35
#798616
I guess it could be but I'm thinking more it's rich up to 3/4000 RPM's. My rings were reused so I suspect they are leaking as well as I know the Viton seals are leaking. I got oil on my finger tip when I had the intake boots off. Not long ago the bases were cleaning up so that's where I'm trying to go by weaning it out little by little.
Last edit: 13 Feb 2019 20:35 by SWest.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
14 Feb 2019 07:45
#798638
Riding as I do, I'm having to add a qt. of oil every 350 miles or so. Changed brand to Shell Rotella T4 last year after running Brad Penn V2 10w-40 prior when the oil was staying in the engine longer.
  • SWest
  • 10 22 2014
14 Feb 2019 09:03
#798647
Yeah, using the power is good for the soul. :woohoo:
  • SWest
  • 10 22 2014
17 Feb 2019 09:10
#798808
Need to lean them out even more.
  • SWest
  • 10 22 2014
20 Feb 2019 10:28
#798940
Might drop the main jet one size.
  • SWest
  • 10 22 2014
25 Feb 2019 20:47
#799234
Still leaning it out.
  • SWest
  • 10 22 2014
24 Mar 2019 15:31 - 24 Mar 2019 15:34
#800978
Leaned #1 a little and richened up the rest a tad. Getting even better.B)
Last edit: 24 Mar 2019 15:34 by SWest.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
24 Mar 2019 18:05
#800981
I torque my spark plugs 20 ft. lbs. per service manual. Had one plug loosen during a ride when I snugged them by hand, so it's been torque wrench from that ride on.
:whistle:
