Mikuni VM 33 Carbs 17 Jan 2019 07:46 #796934
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2621
Pilots are in and the slides don't stick.
Last edit: by SWest. Reason: Caps
Mikuni VM 33 Carbs 17 Jan 2019 11:58 #796952
  • SWest
  • 10 22 2014
Got them back on.
Mikuni VM 33 Carbs 17 Jan 2019 17:09 #796976
  • SWest
  • 10 22 2014
Took it up the road and back. Exhaust note is different and it seems to rev crisper. I'll take a ride tomorrow, check the plugs and post a clip of it taking off. Idle seems more stable too. B)
Mikuni VM 33 Carbs 28 Jan 2019 06:25 #797749
  • SWest
  • 10 22 2014
New plugs but too soon to tell. I know they're real close finally. B)
Mikuni VM 33 Carbs 28 Jan 2019 07:10 #797750
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
Look'n good Steve. Ride the peace out of it brother! B)
1982 KZ1100-A2
Mikuni VM 33 Carbs 28 Jan 2019 07:13 #797751
  • SWest
  • 10 22 2014
With a little help from my friends. B)
Mikuni VM 33 Carbs 13 Feb 2019 06:49 #798588
  • SWest
  • 10 22 2014
Gotta dial in the pilots again this morning. Looks like rain this evening, off and on the rest of the week. At least I'll be able to test ride it today. B)
Last edit: by SWest. Reason: sp
Mikuni VM 33 Carbs 13 Feb 2019 10:31 #798602
  • daveo
  • daveo's Avatar
  • Premium Member
Could the soot on the spark plug base rings be oil residue?
My plugs have that too, and the insulator and electrodes look nearly as good as yours.
Last check I'm adding oil more often than I like, which may indicate the source of the base-ring carbon on my plugs. I have about 20K miles on this set of OEM Kaw rings installed in 2015.
I usually ride in the upper safe RPM range, which in my mind may account for additional piston ring wear if compared to a similar engine run consistently at lower engine revs.
Installed new Viton valve seals in 2015, but I wonder if they may not work as effectively since the cams were changed from standard to ZX at that time, but the 8K mile original valves were just checked and reused.
:huh:
1982 KZ1100-A2
Mikuni VM 33 Carbs 13 Feb 2019 20:34 #798616
  • SWest
  • 10 22 2014
I guess it could be but I'm thinking more it's rich up to 3/4000 RPM's. My rings were reused so I suspect they are leaking as well as I know the Viton seals are leaking. I got oil on my finger tip when I had the intake boots off. Not long ago the bases were cleaning up so that's where I'm trying to go by weaning it out little by little.
Mikuni VM 33 Carbs 14 Feb 2019 07:45 #798638
  • daveo
  • daveo's Avatar
  • Premium Member
Riding as I do, I'm having to add a qt. of oil every 350 miles or so. Changed brand to Shell Rotella T4 last year after running Brad Penn V2 10w-40 prior when the oil was staying in the engine longer.
1982 KZ1100-A2
Mikuni VM 33 Carbs 14 Feb 2019 09:03 #798647
  • SWest
  • 10 22 2014
Yeah, using the power is good for the soul. :woohoo:
Mikuni VM 33 Carbs 17 Feb 2019 09:10 #798808
  • SWest
  • 10 22 2014
Need to lean them out even more.
