$100 1000cc to 1100cc upgrade.
- car5car
- Banned
28 Mar 2016 14:03
I found some interesting info.
81-82 KZ1000 cylinder block can be bored for used 1100 pistons. I found used pistons for $8 set on ebay.
How much is cylinder block boring?
Boring--??????
Pistons $8 +15 shipping probably old rings can be used
2 gaskets ??????
Boring--??????
2 gaskets ??????
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: $100 1000cc to 1100cc upgrade.
28 Mar 2016 16:05
Be careful what you buy for $8. It cost me $500 for my Wiseco's and I know they will last plus if they are stock they will be low compression or the wrist pins will be 18mm not 17.
- Kidkawie
- I bleed premix
28 Mar 2016 16:40
$8 pistons? Good luck with that.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- car5car
- Banned
28 Mar 2016 19:19
It not hard to measure a piston with caliper and engine guy can bore each cylinder for every piston.
- Nebr_Rex
28 Mar 2016 20:52 - 28 Mar 2016 20:56
69.9mm to 72.5mm.......?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 28 Mar 2016 20:56 by Nebr_Rex.
28 Mar 2016 21:07
What's the CR of the $8 pistons. Reuse rings. :huh:
- PLUMMEN
29 Mar 2016 00:54
Its not the $8.00 pistons that are the problem,its the $50.00 or so a hole for boring that gets ya.
And if the rings are shot it just mushrooms from there.
- zed1015
29 Mar 2016 02:39 - 29 Mar 2016 02:45
You can go to 73mm with MTC or Wiseco which is 1105cc but it leaves the liners on the thin side and prone to excessive oil usage and spigot cracking.
Fitting the 1100 (1089cc) block is common practice for a cheap upgrade if you can get a good set but maybe not so if just starting with the s/h pistons.
If you get the cheap 1100 pistons you will still HAVE to buy new rings, circlips, and possibly wrist pins and then the gaskets etc. (all of which are included in an MTC/WISECO KIT )
The price of those OEM parts will not be far off or will most likely exceed the price of a complete new MTC or Wiseco kit and you still end up with a less than perfect job with std comp part worn pistons and no significant performance increase.
False economy.
False economy.
Last edit: 29 Mar 2016 02:45 by zed1015.
The following user(s) said Thank You: PLUMMEN, SWest
29 Mar 2016 07:51
There was a thread here about a set of new pistons and rings for $100. The problem started when the OP asked how the rings were installed. No instructions and the seller wouldn't disclose the name of the manufacturer or contact information. He had two threads on this subject. One he listed the name of the seller that drug KZR into the controversy. Threats of law suits were made and eventually the thread was taken down. The other remains because it doesn't list the name of the seller. It turns out the OP didn't own the bike he was working on, he was doing it for a client who he then gave back the parts and bike then moved on. :dry: That was the end of it.
After looking into these unknown make pistons, I could tell they would be low compression at best and the only advantage I could tell was the displacement increase they would provide. Given the time, cost of boring, gaskets, etc, it would have provided little performance wise and in my book a waste of money. Add to that if a ring was broken while installing them or a miss hap while running them, no replacements would be available. The unknown origin and history also made them a gamble IMO.
Riding a motorcycle is dangerous enough and using CHEAP parts is just asking for trouble. IMO :whistle:
- car5car
- Banned
29 Mar 2016 11:42Recently I paid $60 for boring 4 cyl Toyota block. Maybe bike block needs steel plates attached for boring.PLUMMEN wrote: $50.00 or so a hole for boring that gets ya.
29 Mar 2016 11:52
$200 is average for quality work.
- missionkz
29 Mar 2016 12:28$168.00....is what I paid to have my 1015cc cylinder block bored, honed and piston fitted for the Wiseco 1075cc kit.swest wrote: $200 is average for quality work.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
