$100 1000cc to 1100cc upgrade.
- zed1015
Re: $100 1000cc to 1100cc upgrade.
29 Mar 2016 12:30
Plates not needed for boring.
Boring AND honing needs to be done in order of 2, 4, 1, 3 to avoid incorrect clearances due to heat distortion unless you let the whole block cool after each pass.
For $60 you probably get a wrecked block with poor compression and a high oil usage unless the machinist is a good friend and the $60 is mates rates for beer money.
- baldy110
29 Mar 2016 13:13
Or you can simply get the cylinder and pistons off a KZ1100 or GPz1100 and no machining required, bolts right on.
29 Mar 2016 13:19
I had a lousy bore job done in 78 for $100. Not only were they off center, the bike always burned oil. I had Clupper Racing do my new bores in 87 for $200 and ran them until 13. I'll say it again, you want cheap, you get cheap. :dry:
- pete greek1
29 Mar 2016 15:05+1,swest wrote: I had a lousy bore job done in 78 for $100. Not only were they off center, the bike always burned oil. I had Clupper Racing do my new bores in 87 for $200 and ran them until 13. I'll say it again, you want cheap, you get cheap. :dry:
Pete
- car5car
- Banned
29 Mar 2016 16:21
I was going to buy this tool and use my drill:
www.cylinderheadsupply.com/uncyho.html
96 Yamaha Royal Star
82 Yamaha Virago 920
- car5car
- Banned
29 Mar 2016 16:24 - 29 Mar 2016 16:34Great idea!baldy110 wrote: Or you can simply get the cylinder and pistons off a KZ1100 or GPz1100 and no machining required, bolts right on.
Are there forum members who keep their KZ1100 outside and don't have guns? :evil:
The best upgrade is to sell KZ1000 for 2500 and buy KZ1100 for $1000
Last edit: 29 Mar 2016 16:34 by car5car.
29 Mar 2016 17:35 - 29 Mar 2016 17:36
I wouldn't take 5 1100's for my Z1b 1000. I am thinking on going 1105, spending REAL money and sell my 1015 setup. Maybe a 1200.
Last edit: 29 Mar 2016 17:36 by SWest.
- car5car
- Banned
29 Mar 2016 19:21
I want KZ1100 shaft.
- bluezbike
29 Mar 2016 19:36
Then you should go get one......much more satisfying to ride what you really want.....either way what everyone is saying is true : there are no free lunches when it comes to increasing performance.
79 KZ 1000 LTD
- zed1015
30 Mar 2016 01:00Why ? $149 + $60 gets you a proper accurate re-bore at a professional engine shop by someone who hopefully knows what they are doing.car5car wrote: I was going to buy this tool and use my drill:
Those hones are really for glaze busting and re-ringing and no where near as accurate and consistent as a bench machine.
Total false economy and a recipe for disaster.
The following user(s) said Thank You: missionkz
- KZB2 650
30 Mar 2016 06:31
I trusted APE to do mine...... they have the equipment and have done hundreds if not thousands over the years.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
30 Mar 2016 06:36
What did they charge?
