$100 1000cc to 1100cc upgrade.
  • KZB2 650
  • KZB2 650's Avatar
Re: $100 1000cc to 1100cc upgrade.
30 Mar 2016 06:44
#718196
It was 120 since I bought the pistons from them...... was 175 if not and I see its 189 now........ could a got the pistons a little cheaper but not by much since they had the discount on them doing it all. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
30 Mar 2016 06:49
#718198
Did you bring them to motorcycle engine shop or auto? I am pretty sure automotive machine shop will charge a few times less.
96 Yamaha Royal Star
82 Yamaha Virago 920
  • car5car
  • Banned
  • Banned
30 Mar 2016 06:53 - 30 Mar 2016 06:57
#718199
zed1015 wrote:
car5car wrote: I was going to buy this tool and use my drill:
www.cylinderheadsupply.com/uncyho.html
Why ? $149 + $60 gets you a proper accurate re-bore at a professional engine shop by someone who hopefully knows what they are doing.
Those hones are really for glaze busting and re-ringing and no where near as accurate and consistent as a bench machine.
Total false economy and a recipe for disaster.
I repair car engines all the time. I invented a tool to repair connecting rod journals w/o removing engine. If I try this hone and it works, I'll be able to bore blocks w/o removing engines.
Last edit: 30 Mar 2016 06:57 by car5car.
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Mar 2016 07:03
#718200
The barrels come off without pulling the engine. Trying to bore 2-4mm with a hons is NOT the way to do it. Not only can the bores be uneven, off center or even warped, having a piston grenade at high RPM can be life threatening on a bike not to mention the law suits that come from it if the customer is injured. :dry:
  • PLUMMEN
  • PLUMMEN's Avatar
30 Mar 2016 07:37
#718208
Thats a hone,not a boring bar. :woohoo:
The following user(s) said Thank You: Patton
  • PLUMMEN
  • PLUMMEN's Avatar
30 Mar 2016 07:40
#718209
car5car wrote: Did you bring them to motorcycle engine shop or auto? I am pretty sure automotive machine shop will charge a few times less.
Most,not all automotive machine shops dont have a clue about motorcycle machine work. ;)
The following user(s) said Thank You: KZB2 650, bluezbike
  • car5car
  • Banned
  • Banned
30 Mar 2016 07:43
#718211
swest wrote: The barrels come off without pulling the engine. Trying to bore 2-4mm with a hons is NOT the way to do it. Not only can the bores be uneven, off center or even warped, having a piston grenade at high RPM can be life threatening on a bike not to mention the law suits that come from it if the customer is injured. :dry:
I am not talking about bikes.
  • car5car
  • Banned
  • Banned
30 Mar 2016 07:45
#718214
Of course they don't. That is because car cylinders are round and bike cylinders are square. :)
  • PLUMMEN
  • PLUMMEN's Avatar
30 Mar 2016 07:45
#718216
  • car5car
  • Banned
  • Banned
30 Mar 2016 07:46
#718218
that is why it will take up to one hour to bore a cylinder.
  • PLUMMEN
  • PLUMMEN's Avatar
30 Mar 2016 07:52
#718221
Id be willing to bet after trying it your way they probably do more closely resemble something square than a circle.
So just exactly how long have you been putting motors together ? :P
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Mar 2016 07:54
#718222
I shudder to think of it. :ohmy:
