$100 1000cc to 1100cc upgrade.
- PLUMMEN
Re: $100 1000cc to 1100cc upgrade.
30 Mar 2016 07:56So how exactly do you think a spring loaded hone will make an out of round cylinder round? It is made to follow the existing bore shape,not recreate a circle out of an egg.car5car wrote:that is why it will take up to one hour to bore a cylinder.PLUMMEN wrote:Thats a hone,not a boring bar. :woohoo:car5car wrote: I was going to buy this tool and use my drill:
www.cylinderheadsupply.com/uncyho.html
The following user(s) said Thank You: Patton
30 Mar 2016 08:02 - 30 Mar 2016 08:04car5car wrote:Of course they don't. That is because car cylinders are round and bike cylinders are square.PLUMMEN wrote:Most,not all automotive machine shops dont have a clue about motorcycle machine work.car5car wrote: Did you bring them to motorcycle engine shop or auto? I am pretty sure automotive machine shop will charge a few times less.
You MUST be joking.
Last edit: 30 Mar 2016 08:04 by SWest.
- KZB2 650
30 Mar 2016 08:08
You really need to re think this car5 ...... were talking a couple 10 thousands between running good and lasting and not.....
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- car5car
- Banned
30 Mar 2016 10:07 - 30 Mar 2016 10:12I need stones springloaded with limited movement. That means the tool has to be modified somehow. So it wouldn't work.PLUMMEN wrote: So how exactly do you think a spring loaded hone will make an out of round cylinder round? It is made to follow the existing bore shape,not recreate a circle out of an egg.
I don't get engines with bad cylinders very often.
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 30 Mar 2016 10:12 by car5car.
- bluezbike
30 Mar 2016 10:10
Go for it !!!! If it works then you may have come up with a mythbuster (or luck).....if not....well, then it's back to the drawing board.
79 KZ 1000 LTD
- car5car
- Banned
30 Mar 2016 10:17 - 30 Mar 2016 10:24I bought Dodge Stealth with heads removed in 95, I think. Didn't know anything about engine repair. I had a service manual. Paid about 3k for it, sold for 7k.PLUMMEN wrote: So just exactly how long have you been putting motors together ?
About a year ago I bought 02 Jaguar X-type with manual transmission. I repaired one connecting rod journal. My wife drove it for about a year before I sold it.
What do you do? Repair bike engines?
Last edit: 30 Mar 2016 10:24 by car5car.
30 Mar 2016 10:54
I've repaired everything from chain saws to Ford big blocks and beyond. I'd buy Honda CVCC's for next to nothing, fix them and sell them. Talk about complicated, 50+ vacuum hoses, censers of all types, etc. These bike are simple compared. One thing holds true, the right tool for the job.
Back in the day I would fit a .5 over piston in a dirt bike. No way would I attempt to go over that on any engine. I've taken short cuts out of need but it is only until I could do it right down the road. :whistle:
- PLUMMEN
30 Mar 2016 12:57I do a little of this and a little of that. The BBC in my avatar is my improved version of a zz502 chevy with breathed on iron rect port 990 heads and a few other tweaks,which makes more than enough hp and torque to send that jag trans and independent rear suspension of yours running to the back of the garage with its 1/2 shafts between its legs. :laugh:car5car wrote:I bought Dodge Stealth with heads removed in 95, I think. Didn't know anything about engine repair. I had a service manual. Paid about 3k for it, sold for 7k.PLUMMEN wrote: So just exactly how long have you been putting motors together ?
30 Mar 2016 13:12
Nicely put :woohoo:
- car5car
- Banned
30 Mar 2016 17:45 - 30 Mar 2016 17:46There is nothing faster than my Jaguar with 2.5 Ford engine in it!PLUMMEN wrote:I do a little of this and a little of that. The BBC in my avatar is my improved version of a zz502 chevy with breathed on iron rect port 990 heads and a few other tweaks,which makes more than enough hp and torque to send that jag trans and independent rear suspension of yours running to the back of the garage with its 1/2 shafts between its legs. :laugh:car5car wrote:I bought Dodge Stealth with heads removed in 95, I think. Didn't know anything about engine repair. I had a service manual. Paid about 3k for it, sold for 7k.PLUMMEN wrote: So just exactly how long have you been putting motors together ?
Now I have S-type with 3.0 V6. It is so fast you cannot even see it passing you!
Last edit: 30 Mar 2016 17:46 by car5car.
- PLUMMEN
30 Mar 2016 17:51600hp and 560 ft lbs of torque on 91 octane pump gas would do wonders for that little jag. :woohoo:car5car wrote:There is nothing faster than my Jaguar with 2.5 Ford engine in it!PLUMMEN wrote:I do a little of this and a little of that. The BBC in my avatar is my improved version of a zz502 chevy with breathed on iron rect port 990 heads and a few other tweaks,which makes more than enough hp and torque to send that jag trans and independent rear suspension of yours running to the back of the garage with its 1/2 shafts between its legs. :laugh:car5car wrote:I bought Dodge Stealth with heads removed in 95, I think. Didn't know anything about engine repair. I had a service manual. Paid about 3k for it, sold for 7k.PLUMMEN wrote: So just exactly how long have you been putting motors together ?
30 Mar 2016 18:07
Check and MATE. :woohoo:
