Help with 82 kz250
- 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 16:34Here's the bike I'll get the rest tomorow
Attachment 0905151640-2.jpg not found
- missionkz
Re: HELP PLEASE!!!!
09 Sep 2015 17:26 - 09 Sep 2015 20:40Well, I think you are wrong. .017" gap isn't junk and neither is .027". Large? Yes. But be the cause all these consternations? I just don't think so.82 kz250l wrote: In my experience any ring gap past.017 is JUNK. That's when I noticed lots of blow bye out of the crank case, fuel in the crank case and started to use oil....this is my opinion
I have a feeling it is something else, like the rings simply did not seat or wear in correctly.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 09 Sep 2015 20:40 by missionkz.
Re: HELP PLEASE!!!!
09 Sep 2015 17:31
That gap by itself is not going to cause the problems described. Is that gap the result of worn rings? Maybe, but I don't see how anyone would know that answer without seeing the rings unless they knew what the gap was set to when the rings were new; it may have already been set wide. Ed
- LineArtist
Re: HELP PLEASE!!!!
09 Sep 2015 18:44 - 09 Sep 2015 19:08
Does a 250 have a overhead cam - cam chain?
Whatever is opening valves needs to be set at TDC, otherwise the ignition timing will never be in sync. Sorry but I don't know much about the 250's but think you need to understand the comments about "cam timing".
:huh: < :dry: >>
< :woohoo: !
:huh: < :dry: >>
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
Last edit: 09 Sep 2015 19:08 by LineArtist.
Re: HELP PLEASE!!!!
09 Sep 2015 18:57
:huh:
- 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 23:12 - 10 Sep 2015 02:30missionkz wrote:Well, I think you are wrong. .017" gap isn't junk and neither is .027". Large? Yes. But be the cause all these consternations? I just don't think so.82 kz250l wrote: In my experience any ring gap past.017 is JUNK. That's when I noticed lots of blow bye out of the crank case, fuel in the crank case and started to use oil....this is my opinion
What do you think could be the problem the rings?
Last edit: 10 Sep 2015 02:30 by 82 kz250l.
- 82 kz250l
Re: HELP PLEASE!!!!
10 Sep 2015 01:04LineArtist wrote: Does a 250 have a overhead cam - cam chain?
:huh: < :dry: >>< :woohoo: !
Yes it does....I do understand cam timing....only reason I adjusted it was to get the bike to do something else than what it was doing (good or bad) I have thrown everthing an the ketchin sink at this bike that's why I'm here.....I have built many dirt bike an atv engines. an never cam acrossed something like this that I couldn't figure out
- 82 kz250l
Re: HELP PLEASE!!!!
10 Sep 2015 03:26 - 10 Sep 2015 03:50Attachment 0910150825b.jpg not found
Attachment 0910150821.jpg not found
Attachment 0910150817a.jpg not found
Attachment 0910150830.jpg not found
Attachment 0910150829.jpg not found
after double checking the ring gap was .034
Last edit: 10 Sep 2015 03:50 by 82 kz250l.
- 82 kz250l
Re: HELP PLEASE!!!!
10 Sep 2015 04:08650ed wrote: That gap by itself is not going to cause the problems described. Is that gap the result of worn rings? Maybe, but I don't see how anyone would know that answer without seeing the rings unless they knew what the gap was set to when the rings were new; it may have already been set wide. Ed
I know the gap is not causing the problem....the gap is telling me the rings are worn out.....in the past where the ring gap was in my liking. And the engine had low compression I have re honed the cylinder an used the rings over again. In situations like that I have figured out loss of compression is from the cylinder glazing
Re: HELP PLEASE!!!!
10 Sep 2015 04:55
From the look of the bore, the rings were "chattering". Put the piston in the bore and use a feeler gauge to measure the clearance, top, middle and bottom. If all good, do a cross hatch hone with 180/220 grit stones. By the look of the RTV, someone was in there before. New rings, valve guide seals, a valve lap and gaskets, it should run.
Re: HELP PLEASE!!!!
10 Sep 2015 05:16
Time to start a new thread in the engine section. Can transfer the bore and piston there.
- KZQ
- Administrator
Re: HELP PLEASE!!!!
10 Sep 2015 05:50
I moved it back to the Engine forum.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
