Help with 82 kz250
  • 82 kz250l
  • 82 kz250l's Avatar Topic Author
Re: HELP PLEASE!!!!
09 Sep 2015 08:56
#689339
1977-Z1-A1-LTD wrote: You may have tried this since I'm late to the party, but it sounds like a carb issue to me, and in fact un-metered fuel being dumped directly into the cylinder. If you're fouling the plug, you should also be seeing black smoke from the exhaust. Does the bowl vent have any fuel in it? If so, you may need to try "lapping" the float needle to make sure it has a really good seat, be sure the floats are not touching the top of the float bowl when you push down on the float/needle when the carb is upside down. Another check is a "pop-off" test, with the carb upside down and the floats and needle in place, put a bit of soapy water around the float needle and blow some air into the fuel intake port on the carb (less than 10 psi). If you see bubbles the float needle is leaking. I feel your pain, went through the exact same thing on 4 carbs..
Thanks for the info but I think it's a compression problem not a carb problem....I originally had this in the engine section but it got moved here for some reason
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 08:58
#689340
missionkz wrote: Yes low compression means incomplete combustion and rich mixture symptoms.
I would think a used engine should be compressing more like 135-150 psi range.
I think your right the book says between 119-185psi
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: HELP PLEASE!!!!
09 Sep 2015 10:11
#689344
Did you check your cam timing?
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 10:28
#689346
swest wrote: Did you check your cam timing?
Yes I advanced it an retard it...an there was no change to the way it was runing
  • pete greek1
  • pete greek1's Avatar
Re: HELP PLEASE!!!!
09 Sep 2015 11:02
#689351
When you did the compression check did you have it WOT ?
Pete
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 11:37
#689355
pete greek1 wrote: When you did the compression check did you have it WOT ?
Pete
Yes sir
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: HELP PLEASE!!!!
09 Sep 2015 11:39
#689356
I didn't mean your ignition timing. If you advance or retard the cam timing you run the risk of bent valves.
  • 1977-Z1-A1-LTD
  • 1977-Z1-A1-LTD's Avatar
Re: HELP PLEASE!!!!
09 Sep 2015 11:51
#689357
I went back through previous posts, and I know you indicated checking the cam timing, but what you're describing with low compression and an accumulation of un-ignited fuel in the cylinder could be a sticking (or bent) valve or the push rod is bent and not opening the valve, etc. Did you also check valve clearances?
1977 KZ1000 LTD
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 12:12
#689362
1977-Z1-A1-LTD wrote: I went back through previous posts, and I know you indicated checking the cam timing, but what you're describing with low compression and an accumulation of un-ignited fuel in the cylinder could be a sticking (or bent) valve or the push rod is bent and not opening the valve, etc. Did you also check valve clearances?
The valves are good I have the top end tore down now I'm gona replace the rings an go from there
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 12:15
#689364
Far as I know theirs no way to adjust the ignition timing
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: HELP PLEASE!!!!
09 Sep 2015 12:16
#689365
Fill the ports with gas or some kind of solvent and see if the valves leak. It doesn't take much. Low miles, the rings should be still good.
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 12:20
#689366
swest wrote: Fill the ports with gas or some kind of solvent and see if the valves leak. It doesn't take much. Low miles, the rings should be still good.
So far they have been soking for 2 hrs an the gas is still in there no leaks as I can tell
The ring end gap was 25 thousands...the rings are junk
