Help with 82 kz250
- 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 03:33Do you have any suggestion of what could be wrong with my bike?swest wrote: You wouldn't be asking about compression figures. :whistle:
- punisher11b
Re: HELP PLEASE!!!!
09 Sep 2015 04:34
I had the problem of no airbox on my kz440. After 3 months of trying to tune those "bleeping" CV carbs I just took them off and never looked back. Put in a 2 in 1 intake with a $70 vm-34 carb. One week of jetting and blam. Runs way better than with the CV carbs. Just with half the gas mileage ( but more guts). Just my 2 cents. Get the original set up or toss those CV carbs.
- good luck
- 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 04:39punisher11b wrote: I had the problem of no airbox on my kz440. After 3 months of trying to tune those "bleeping" CV carbs I just took them off and never looked back. Put in a 2 in 1 intake with a $70 vm-34 carb. One week of jetting and blam. Runs way better than with the CV carbs. Just with half the gas mileage ( but more guts). Just my 2 cents. Get the original set up or toss those CV carbs.[/quote
I tride a carb off of a lt230 quad it ain't a cv carb an there was no change
Re: HELP PLEASE!!!!
09 Sep 2015 04:48
Time for a manual and check compression,cam timing,etc.
- 82 kz250l
- KZQ
- Administrator
Re: HELP PLEASE!!!!
09 Sep 2015 06:47
I moved this thread from the engine forum to the carburetor forum and re-titled so that future 250 owners could find it.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Re: HELP PLEASE!!!!
09 Sep 2015 07:4482 kz250l wrote: 62psi dry an 95psi wet
That's awful low compression, especially for a single.
- 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 07:49swest wrote:82 kz250l wrote: 62psi dry an 95psi wet
That's what I was thinking but wasant to shure....an idk if low compression would cause my bikes symptoms
Re: HELP PLEASE!!!!
09 Sep 2015 07:55
Yes it would. Can't burn the fuel. How many miles on it? Might have to be moved back to engine section or start a new thread. :dry:
- missionkz
Re: HELP PLEASE!!!!
09 Sep 2015 07:58
Yes low compression means incomplete combustion and rich mixture symptoms.
I would think a used engine should be compressing more like 135-150 psi range.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- 1977-Z1-A1-LTD
Re: HELP PLEASE!!!!
09 Sep 2015 08:12
You may have tried this since I'm late to the party, but it sounds like a carb issue to me, and in fact un-metered fuel being dumped directly into the cylinder. If you're fouling the plug, you should also be seeing black smoke from the exhaust. Does the bowl vent have any fuel in it? If so, you may need to try "lapping" the float needle to make sure it has a really good seat, be sure the floats are not touching the top of the float bowl when you push down on the float/needle when the carb is upside down. Another check is a "pop-off" test, with the carb upside down and the floats and needle in place, put a bit of soapy water around the float needle and blow some air into the fuel intake port on the carb (less than 10 psi). If you see bubbles the float needle is leaking. I feel your pain, went through the exact same thing on 4 carbs..
1977 KZ1000 LTD
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
The following user(s) said Thank You: 82 kz250l
- 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 08:44 - 09 Sep 2015 08:47
3382 miles
the piston ring end gap Is .025
Last edit: 09 Sep 2015 08:47 by 82 kz250l.
