Help with 82 kz250
  • moneypit
  • moneypit's Avatar
Re: HELP PLEASE!!!!
08 Sep 2015 15:42
#689219
Are the float heights correct?
2-76 kz900
St Paul MN
  • 82 kz250l
  • 82 kz250l's Avatar Topic Author
Re: HELP PLEASE!!!!
08 Sep 2015 16:35
#689223
Yes sir
  • 82 kz250l
Re: HELP PLEASE!!!!
08 Sep 2015 16:37 - 08 Sep 2015 17:23
#689224
:woohoo: As of now in on my forth different carb
Last edit: 08 Sep 2015 17:23 by 82 kz250l.
  • 82 kz250l
Re: HELP PLEASE!!!!
08 Sep 2015 17:29
#689234
:angry:
  • missionkz
  • missionkz's Avatar
Re: HELP PLEASE!!!!
08 Sep 2015 17:31
#689235
Have you had a chance to check the compression ?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: 82 kz250l
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: HELP PLEASE!!!!
08 Sep 2015 21:17
#689257
You're getting a good supply of fuel, the same response with multiple carbies, with or without an airbox.
It's probably not carby related in this case, as I would expect things to change as soon as you change the carby. However, your plug is black, which means you are running rich. But if you've been using the choke, that's to be expected.
I'd be looking for an air leak, maybe a carb vent or your inlet not sealing correctly. After that, things get much more complicated, as you'll need to start looking at timing (which you said you already have with no effect). Next step is the engine itself - I think you're due for a compression test.
1981 KZ750 LTD
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 02:05 - 09 Sep 2015 02:45
#689260
If I turn the choke on it dies...I put grease around the intake boot between the head an boot an around the diaphragm seal between the carb an top cover....in going to do a compression test today wahat psi should it have?
AGAIN THSNKS FOR THE HELP AN ALL OF YALLS TIME
Last edit: 09 Sep 2015 02:45 by 82 kz250l.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • martin_csr
  • martin_csr's Avatar
Re: HELP PLEASE!!!!
09 Sep 2015 03:13 - 09 Sep 2015 03:19
#689271
The carbs have been cleaned 7 times or more, at least 4 different carburetors have been installed, and you've tried removing the muffler, making a pod airbox & duct taping the pod filters. This is why elr658 from another forum usually suggests taking a phillips head screwdriver, heating it to red hot, them jamming it in your eye, as it would be less painful than trying to tune cv carburetors for individual filters. :laugh:
CV carburetor animation.
Last edit: 09 Sep 2015 03:19 by martin_csr.
The following user(s) said Thank You: Jbosh
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 03:18
#689273
swest wrote: You need a manual.
Manuals are overrated lol
  • 82 kz250l
Re: HELP PLEASE!!!!
09 Sep 2015 03:21
#689275
martin_csr wrote: The carbs have been cleaned 7 times or more, at least 4 different carburetors have been installed, and you've tried removing the muffler, making a pod airbox & duct taping the pod filters. This is why elr658 from another forum usually suggests taking a phillips head screwdriver, heating it to red hot, them jamming it in your eye, as he says it would be less painful than trying to tune cv carburetors for individual filters. :laugh:
Lol it's a single sulinder engine I thought it would be stupid simple to work on......I was wrong I so,t had this much trouble with my 76 cb750
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: HELP PLEASE!!!!
09 Sep 2015 03:22
#689276
You wouldn't be asking about compression figures. :whistle:
