Help with 82 kz250
- 82 kz250l
07 Sep 2015 21:33 #689088
by 82 kz250l
HELP PLEASE!!!! was created by 82 kz250l
I have 82 kz 250 that i have been having problems with...... Ok the problem is it will not go above a ideal. The slight twist of the throttle it dies. When it dies it blows gas out of the carb......
Now what i have done\tried
1..Cleand the carb 7 times... no change what so ever
2..I set the timing advanced an retard ... no change what so ever
3..Put a different carb on it....no change at all
4..I took the muffler off.... no change
5..New plug an fuel
NOTE... it has the cv 32 carb....if i put it on chock it dies....it has a pod filter
5..New plug an fuel
- daveo
- Thank you received: 655
08 Sep 2015 02:19 #689096
by daveo
1982 KZ1100-A2
Replied by daveo on topic HELP PLEASE!!!!
It probably would run better with the factory air box.
1982 KZ1100-A2
- Thank you received: 2829
08 Sep 2015 02:25 #689097
by 650ed
Replied by 650ed on topic HELP PLEASE!!!!
+1 !
Tuning CV carbs for pod filters is quite a challenge simply because of the way CV carbs work. Why change to pods? Ed
- Thank you received: 1656
08 Sep 2015 04:30 - 08 Sep 2015 04:31 #689116
by martin_csr
Replied by martin_csr on topic HELP PLEASE!!!!
If you don't have the stock airbox, you'll need to stabilize the air flow into the carburetor.
Something like this, but additional carb tuning may be needed. Custom Air Box for KZ440.
Last edit: 08 Sep 2015 04:31 by martin_csr.
- 82 kz250l
08 Sep 2015 06:10 #689136
by 82 kz250l
Replied by 82 kz250l on topic HELP PLEASE!!!!
the po took the airbox off an put the pod filter on it...idk why he did
- 82 kz250l
08 Sep 2015 06:13 #689137
by 82 kz250l
today i adjusted the valves...an still no change
Thanks for the suggestions everybody ill try them out an get back with yall soon
- MDZ1rider
- Thank you received: 118
08 Sep 2015 07:12 #689143
by MDZ1rider
Replied by MDZ1rider on topic HELP PLEASE!!!!
I don't have much experience with CV carbs, but your symptoms sounds like a fuel starvation issue. Check to make sure you have good flow at the fuel line. Low flow could be the petcock, an inline filter or bend/clog in the line. If you have good flow check float needle valve assembly and float level setting. You're getting just enough fuel for idle. Anything more and the flow can't keep up.
- 82 kz250l
08 Sep 2015 07:39 #689148
by 82 kz250l
I'm getting great flow of fuel....every time I take the carb off to triple check my work the intake boot has raw gas in it....an the fuel air screw dont change nothing screws all the way in or out an I have it set 1 an 1/4 turns out
- Thank you received: 2824
08 Sep 2015 07:50 #689149
by Nessism
Replied by Nessism on topic HELP PLEASE!!!!
Wrap your pod with duct tape and block about 2/3 of the surface area and try again. Also open the pilot screw to 3 turns open.
- missionkz
08 Sep 2015 08:36 - 08 Sep 2015 08:37 #689159
by missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Replied by missionkz on topic HELP PLEASE!!!!
Everybody is telling him to make it richer and he is saying gas is pouring in already..... sounds more like the float needle is wide open or the slide needle is pulled all the way with a stuck diaphragm and or maybe there is no main or pilot jet in the holder... LOL
Does it use one of those goofy vacuum fuel selectors where a blown gasket is pouring gas into the carb through a vacuum nipple on the carb?
Bruce
1977 KZ1000A1
Last edit: 08 Sep 2015 08:37 by missionkz.
- 82 kz250l
08 Sep 2015 15:11 #689217
by 82 kz250l
ive tried the duct tape...no luck Made an air box...no change
it does not have any vacum ports on the carb
all jets are clear... the diaphragm am slide move smoothly
- 82 kz250l
08 Sep 2015 15:29 - 08 Sep 2015 15:33 #689218
by 82 kz250l
brand new plug was black after 30 min tops of run time
Last edit: 08 Sep 2015 15:33 by 82 kz250l.
