Help with 82 kz250
- 82 kz250l
HELP PLEASE!!!!
07 Sep 2015 21:33
I have 82 kz 250 that i have been having problems with...... Ok the problem is it will not go above a ideal. The slight twist of the throttle it dies. When it dies it blows gas out of the carb......
Now what i have done\tried
1..Cleand the carb 7 times... no change what so ever
2..I set the timing advanced an retard ... no change what so ever
3..Put a different carb on it....no change at all
4..I took the muffler off.... no change
5..New plug an fuel
NOTE... it has the cv 32 carb....if i put it on chock it dies....it has a pod filter
5..New plug an fuel
- daveo
Re: HELP PLEASE!!!!
08 Sep 2015 02:19
It probably would run better with the factory air box.
1982 KZ1100-A2/1170 sleeper 😀
Re: HELP PLEASE!!!!
08 Sep 2015 02:25
+1 !
Tuning CV carbs for pod filters is quite a challenge simply because of the way CV carbs work. Why change to pods? Ed
Re: HELP PLEASE!!!!
08 Sep 2015 04:30 - 08 Sep 2015 04:31
If you don't have the stock airbox, you'll need to stabilize the air flow into the carburetor.
Something like this, but additional carb tuning may be needed. Custom Air Box for KZ440.
Last edit: 08 Sep 2015 04:31 by martin_csr.
- 82 kz250l
Re: HELP PLEASE!!!!
08 Sep 2015 06:10
the po took the airbox off an put the pod filter on it...idk why he did
- 82 kz250l
Re: HELP PLEASE!!!!
08 Sep 2015 06:13
today i adjusted the valves...an still no change
Thanks for the suggestions everybody ill try them out an get back with yall soon
- MDZ1rider
Re: HELP PLEASE!!!!
08 Sep 2015 07:12
I don't have much experience with CV carbs, but your symptoms sounds like a fuel starvation issue. Check to make sure you have good flow at the fuel line. Low flow could be the petcock, an inline filter or bend/clog in the line. If you have good flow check float needle valve assembly and float level setting. You're getting just enough fuel for idle. Anything more and the flow can't keep up.
- 82 kz250l
Re: HELP PLEASE!!!!
08 Sep 2015 07:39
I'm getting great flow of fuel....every time I take the carb off to triple check my work the intake boot has raw gas in it....an the fuel air screw dont change nothing screws all the way in or out an I have it set 1 an 1/4 turns out
Re: HELP PLEASE!!!!
08 Sep 2015 07:50
Wrap your pod with duct tape and block about 2/3 of the surface area and try again. Also open the pilot screw to 3 turns open.
- missionkz
Re: HELP PLEASE!!!!
08 Sep 2015 08:36 - 08 Sep 2015 08:37
Everybody is telling him to make it richer and he is saying gas is pouring in already..... sounds more like the float needle is wide open or the slide needle is pulled all the way with a stuck diaphragm and or maybe there is no main or pilot jet in the holder... LOL
Does it use one of those goofy vacuum fuel selectors where a blown gasket is pouring gas into the carb through a vacuum nipple on the carb?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 08 Sep 2015 08:37 by missionkz.
- 82 kz250l
Re: HELP PLEASE!!!!
08 Sep 2015 15:11
ive tried the duct tape...no luck Made an air box...no change
it does not have any vacum ports on the carb
all jets are clear... the diaphragm am slide move smoothly
- 82 kz250l
Re: HELP PLEASE!!!!
08 Sep 2015 15:29 - 08 Sep 2015 15:33
brand new plug was black after 30 min tops of run time
Last edit: 08 Sep 2015 15:33 by 82 kz250l.
