1978 kz750 smoke
  • Soxx4u
  • Soxx4u's Avatar Topic Author
Re: 1978 kz750 smoke
14 Jun 2015 09:23
#676520
I am 19 years old and don't know everything let alone have micrometers or bore gauges. The reason why it is smoking was because I tor a valve seal so it was pulling oil in. I replaced it and now no smoke. I believe that the popping sound I said it had might be because of the points/ stator thing on the crank case and also might have to replace the cool pack and wires. I am going to go throught the carbs again and do anothe bench tune. I
  • Soxx4u
14 Jun 2015 09:28
#676521
Is the intake I have ok or is it bad
  • Tyrell Corp
  • Tyrell Corp's Avatar
14 Jun 2015 09:38
#676524
The CV carbs are really sentsitive to air filters and exhuasts, so getting it to run right through those short drag pipes and intake might be a challenge. If you have cleared the smoking the I'd look to the carbs next, clean them out and look at the jetting and needles. They might have been set up before, but unless you had it running good then you don't really know.
That bike is really cool and you have done well getting so far.
  • missionkz
  • missionkz's Avatar
14 Jun 2015 11:03 - 14 Jun 2015 11:05
#676531
Soxx4u wrote: Ok. In my video I give it a light rev and it smokes is that because the rings are new or might I have damaged a valve seal
OK... so you have replaced the bad valve guide seal since this .mov?
www.kzrider.com/media/kunena/attachments...32D-7AF86A21C415.mov
I'm sorry I didn't review the entire thread but are the carbs stock?
On another note:
I helped a buddy run a 2 x 2:1 exhaust with a single, side draft, 44mm Mikuni on a 900 once upon a time... it was not an easy task to get it set up right and to be honest, except being different and looking cool, it never ran any where as good as it did with the stock 28mm carbs.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 14 Jun 2015 11:05 by missionkz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Soxx4u
14 Jun 2015 13:49
#676559
I cleaned the carbs throughly and now it doesn't hessitate as much as it did upon acceleration it's still there though. I don't know the size of my carbs the only thing I found was a 120 on the butterflies. I live in Denver co so elevation is 5280 ft. I don't know if my jets are a problem cause when I'm on the gas wide open it runs but when I cruize it hesitates and that where I get the popping action
  • bountyhunter
  • bountyhunter's Avatar
14 Jun 2015 13:57 - 14 Jun 2015 14:01
#676560
Tyrell Corp wrote: The CV carbs are really sentsitive to air filters and exhuasts, so getting it to run right through those short drag pipes and intake might be a challenge. If you have cleared the smoking the I'd look to the carbs next, clean them out and look at the jetting and needles. They might have been set up before, but unless you had it running good then you don't really know.
That explains the popping, hesitation and poor running. It's probably way too lean. The stock BS-38 carbs came with 45 pilots and 125 main jets. God only knows what this thing would need. I would definitely go up to 50 pilots. The needles will probably have to be shimmed to get any kind of decent off idle response. Some needles have adjustment slots.
Last edit: 14 Jun 2015 14:01 by bountyhunter.
  • bountyhunter
14 Jun 2015 14:00
#676562
Soxx4u wrote: I am 19 years old and don't know everything let alone have micrometers or bore gauges. The reason why it is smoking was because I tor a valve seal so it was pulling oil in. I replaced it and now no smoke. I believe that the popping sound I said it had might be because of the points/ stator thing on the crank case and also might have to replace the cool pack and wires. I am going to go throught the carbs again and do anothe bench tune. I
First is to set the fuel levels with a clear tube, bench tuning is basically a waste of time.
  • Tyrell Corp
14 Jun 2015 14:28
#676568
The good news here being it seems you are way out your carb jetting, although setting these up is time consuming and one rarely gets it right first time, or 3rd or 4th quite often.
It is nice to have a bike that runs like a bag of shit, then making a few minor changes and then it comes to life.
Sometimes feeling the change is important, so after checking/resetting your float fuel levels with a clear tube U bend, try lifting the needles for the main jets, shim with some tiny washers. If it gets better or worse then tune accordingly. Even if you make it worse, that is good as you are narrowing down the problem.
Better than trial and error is someone to point you in the right direction, the 750 twins are quite rare here so good luck. Generally, open filters for a cv carb is upjetting and lifting the needle as a minumum, bigger pilot jets likely and if you are keen changing the air jets and lots of other tweaks. Getting it 90 percent right is the easy bit...
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Jun 2015 16:47
#676575
With that intake system it will be damn near impossible to tune it right. If you don't believe me, try with it off. CV carbs are very forgiving of elivation changes. That's where they shine. Custom intakes and exhausts create the problems. What you have is not engineered for performance. More like a tractor or lawn mower. :whistle: Looks cool though. :woohoo:
  • Soxx4u
14 Jun 2015 17:36
#676584
I took that intake off and it runs a little better still some pop but a lot better than it was. Now here is the big question should I go with pod filters or just rock it with nothing on there I do not want to go to stock intake
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Jun 2015 17:48
#676590
Pods, don't go naked. :ohmy:
