1978 kz750 smoke
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1978 kz750 smoke
27 May 2015 15:06
#674062
Or upside down. You don't have a manual?
  • Tyrell Corp
  • Tyrell Corp's Avatar
27 May 2015 15:40
#674070
Just unbolt the sump, you can usually get away with re-using sump gaskets. Grinding-in the valves and cleaning the carbs won't cost much but if it is runnig real nice you can ask top dollar.
If you are trying to make some $$$ out of this, take plenty of good pics as you go along. In the classic car biz, a big history file plus loads of pics of, for example, a bare metal respray and new panels welded in etc etc adds value and removes the risk factor buying unknown. The same applies to bikes, a top end rebuild done well with receipts and pics will add value.
The 750 twins were not a big seller for kawasaki in the day, they were trying to tap into the xs650 twin and Truimph Bonnerville market, just it wasn't a big seller; the four cylinder kawasaki bikes had really overshadowed the twins. Hence the importance of getting this running really nice of you want to make some dollar. Good luck.
  • Soxx4u
  • Soxx4u's Avatar Topic Author
27 May 2015 17:09
#674086
Cylinder gasket is stuck on crank case how can I remove this
Attachment image-3.jpg not found
  • Soxx4u
27 May 2015 17:10
#674087
I have the disasembly printed from the internet
  • Tyrell Corp
27 May 2015 19:06
#674098
Shave it off carefully with a razor blade, solvent will help on the stuck on bits.
  • Soxx4u
31 May 2015 07:05
#674611
I just got the motor assembled and into the bike I have a few more things to button up. Was curious on how I should break the rings in. I hear you warm in up by rev 2k-5k bursts. Then once warm do about ten pulls from 30-50 mph. What do you guys think
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 May 2015 07:56
#674617
Please don't rev it like that. Ride it like you would normally but not over 4/5000 RPM the first 500 miles. Use the power, keep changing the RPM's and use the engine while braking. The rings should seat right away. Re-tighten after warm up. Change the oil after 500 miles and ride the piss out of it. :woohoo:
  • Soxx4u
31 May 2015 09:03
#674625
What should I re tighten. Head bolts?
Cam bolts?
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
31 May 2015 09:27
#674626
Don't use synthetic oil during the break in process either is one I've heard.
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 May 2015 12:40
#674640
Head bolts and use store brand oil.
  • Soxx4u
31 May 2015 17:17
#674666
I got the motor running but when I took it for a spin I got about thirty feet and it started sputtering didn't even get out of first gear any ideas. Trying to load a video as well
  • Soxx4u
31 May 2015 17:20
#674671
Video
