1978 kz750 smoke
  • Soxx4u
  • Soxx4u's Avatar Topic Author
Re: 1978 kz750 smoke
01 Jun 2015 19:40
#674898
It connects one intake to the other
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jun 2015 19:46 - 01 Jun 2015 19:47
#674900
That's a twin. try pinching the hose to see if it stops. You should have plugs. The ports are for sync not to equalize the carbs.
Last edit: 01 Jun 2015 19:47 by SWest.
  • Soxx4u
01 Jun 2015 19:58
#674905
Ok. In my video I give it a light rev and it smokes is that because the rings are new or might I have damaged a valve seal
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jun 2015 20:03
#674907
Did you plug the ports? Retighten the head? You need to get some miles on it to be sure.
  • 80B4
  • 80B4's Avatar
02 Jun 2015 05:57
#674951
Leave the tube between the manifolds in place, it is a "balancer tube" according to Kawasaki. Every early 750 twin I've seen has that tube in place all the time.
1980B4 1000
1978 Z1R
1978 B3 750
  • Soxx4u
13 Jun 2015 14:53
#676445
Update.... I put new rings valve guide seals and also lapped the valves new cylinder gasket and head gasket. I took it out on the highway today. It stills smokes and now I have a bad pop as well as doing highway speed it wants to shut off but when I get back to side street speed it doesn't want to die and thoughts
  • missionkz
  • missionkz's Avatar
13 Jun 2015 20:01
#676468
Soxx4u wrote: Update.... I put new rings valve guide seals and also lapped the valves new cylinder gasket and head gasket. I took it out on the highway today. It stills smokes and now I have a bad pop as well as doing highway speed it wants to shut off but when I get back to side street speed it doesn't want to die and thoughts
This is a tough one because I have gotten away with doing what you did.
However, what was the condition of the pistons and cylinders before doing all this? Did you mic the pistons and bores to see if a fresh set of rings can be used?
It can be a crap shoot to put new rings on worn out pistons and cylinder bores... just pray it doesn't use oil.
From what I see in the .mov .... it is burning way too much oil for new rings and all that rot.
I'm thinking the pistons and cylinder are too far gone and you need a .50mm over bore min with new pistons and rings.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • bountyhunter
  • bountyhunter's Avatar
13 Jun 2015 22:50 - 13 Jun 2015 22:51
#676486
Did you hone the cylinders?
Have you checked compression?
That sounds more like vacuum leak/carburetor problems. Has the fuel system been cleaned, bowl levels set, etc?
Make sure your gas cap vent is open or you could be vacuum locking for fuel.
Last edit: 13 Jun 2015 22:51 by bountyhunter.
  • bountyhunter
13 Jun 2015 22:56 - 13 Jun 2015 22:58
#676487
Soxx4u wrote: There is a rubber hose at the intake between the carbs and cylinder head. It doesn't pop that bad just slightly. I'll try and upload another video to show you if possible.
FYI, the 750 twins have a vacuum line between the two intake manifolds (carb holders) it's an equalizer tube. It should be there for normal running.
Last edit: 13 Jun 2015 22:58 by bountyhunter.
  • bountyhunter
13 Jun 2015 22:59
#676488
Back when I rebuilt my 750 twin, the carbs "dried out" while I worked on the engine (I stored them empty for a couple of weeks) and ran like crap when I put the engine back together.
  • Tyrell Corp
  • Tyrell Corp's Avatar
14 Jun 2015 08:40
#676513
missionkz wrote: However, what was the condition of the pistons and cylinders before doing all this? Did you mic the pistons and bores to see if a fresh set of rings can be used?
I said this weeks ago, Op didn't seem very receptive to our advice and went is own way on it.
It is pissing in the wind rebuilding a motor without checking basics like installed ring gaps and bore clearance - even a rough feeler guage test,
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Jun 2015 08:55
#676516
Did you check out the intake system he has on that thing?
