1978 kz750 smoke
- Soxx4u
1978 kz750 smoke
21 May 2015 17:12
Help please. 78 kz750 blows white smoke out of one cylinder. Compression test showed 90 psi. Where can I find rings
- bountyhunter
- bountyhunter
Re: 1978 kz750 smoke
21 May 2015 20:04
Before you blindly assume it's rings, I recommend you check the valves and valve seals. Also: how many miles on the engine?
- Soxx4u
21 May 2015 20:45
I checked the valves they are within spec they measure .10 How would I know if my vavle seals are bad and i do not know how many miles are on the motor.
21 May 2015 21:15
You can pull the carbs and see oil on the valves, exhaust if you take off the pipes.
21 May 2015 21:16
Constant smoking does suggest rings.
- Soxx4u
21 May 2015 21:35
I have oil in my exhaust pipe and it smoke a lot of white all the time. I only ran the motor for about 2 mins though
- Tyrell Corp
21 May 2015 22:17
I only ran the motor for about 2 mins though :laugh:
Any oil that you put in your bores during the 'wet' compression test will take some time to clear.
Low compression could be gummed up rings, common on bikes that have been unused for any length of time, often they free themselves just with use.
- bountyhunter
21 May 2015 22:49 - 21 May 2015 22:51I did not mean valve clearance, I mean valves, seats and seals. The valve stem seals on these twins are notorious for failing and then they leak oil through the seats and build up gunk until they don't seal well.Soxx4u wrote: I checked the valves they are within spec they measure .10 How would I know if my vavle seals are bad and i do not know how many miles are on the motor.
Look at the spark plugs and see if you find any oil residue. That will likely mean a seal has failed.
I would change the oil and run it a while before doing anything.
Last edit: 21 May 2015 22:51 by bountyhunter.
- Soxx4u
22 May 2015 08:38
Do you think if I use marvel mystery oil that might help
22 May 2015 11:43
I've had it do some amazing things. Old Gas crawler 4 cylinder sitting for years. Put some in the cylinders, had to turn it back and forth to free it up, let it sit overnight, rebuilt the carb, it fired right up and bladed our road at Hole In The Hills. Worth a shot.
- bountyhunter
22 May 2015 13:06Soxx4u wrote: Do you think if I use marvel mystery oil that might help
I have read people shoot Pb blaster down the spark plug holes to free up stuck rings. Just make sure you change the engine oil before running if you are going to do "soaks" with solvents, cleaners or other chemicals.
