1978 kz750 smoke
Re: 1978 kz750 smoke
31 May 2015 17:21
Bugs.
- Soxx4u
31 May 2015 17:37
Are you trying it direct? Might be too large. You may have to go a third party like you tube, drop box etc.
- Soxx4u
01 Jun 2015 17:02
Update...
Ok so the sputtering was because the air filter had a sponge like screen thing for a filter. The bike runs good smoking is almost completely gone. It has a small back fire to the cylinder that was smoking to begin with. When I disassembeles the motor the alignment marks were pointing at each other according to the manual the intake should be pointing to the rear and then count 32 pins and align the arrow for the exhaust can to that. I went with the manual and now it's doing this popping back fire thing. I also lapped the valves. And ideas?
Attachment trim.F07912CD-815F-4ED1-B6BC-A5344DDCD6FE.mov not found
01 Jun 2015 18:02
Do you have any blow by? Did you change the valve guide seals?
- Soxx4u
01 Jun 2015 18:14
So when I found this problem out there was a lot of oil in the exhaust. I did not clean it out which I should have. I have let the bike run a few times now and it seems like all the oil in the exhaust is almost gone I belive that is the smoke. I ran it again today and there is little to no oil comming out now just that little bit of a popping backfire
01 Jun 2015 18:19
Does it have air injection ports? Syncing the 550, it popped like that when I revved it. I forgot to connect one vacuum line to the injector valve, the popping was still there, just not as bad. That's when I noticed the open port. Connected the line and it went away.
- Soxx4u
01 Jun 2015 19:25
There is a rubber hose at the intake between the carbs and cylinder head. It doesn't pop that bad just slightly. I'll try and upload another video to show you if possible.
- Soxx4u
01 Jun 2015 19:32
There's no air injectors. What is the hose connected to if anything.Lean miss.
- Soxx4u
- Soxx4u
01 Jun 2015 19:36Attachment trim.082C61AB-ED03-4082-832D-7AF86A21C415.mov not found
