KZ1K'S ENGINE PROJECT
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- kz1k
yeah larry i have been using the razor blade and die grinder teq.1 box single edge razor blades
Right angle die grinder & scuff pad kit
Base gaskets are the worst but with the studs removed it's a lot easier. Since I always go with APE studs they're out of the way anyway....
Any spots left come right off in the blasting cabinet.
1978 KZ1000A2
- PLUMMEN
- Thank you received: 104
what the hell happened to your fins,and why did they put that nasty silver paint on there? :Swell its here. i have a question.....the cam towers on one side were fastened flush and the other side was not. is this a problem?
- Old Man Rock
- Thank you received: 225
Is that really paint or deceptive lighting in the image?
I was under the impression they where bead blasting it pre head work no... Well if they painted it I'd be pissed as well...
Joe, don't forget and don't be shy with the amounts, engine/lifter lube on those cams, under the cam bearing/caps, valve buckets/shims etc....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- kz1k
fins broke.....not sure when. its not painted...sand blasted....ill go over it with a bead blast. looks shitty i know. he wanted $60 to paint it...i said no. and he wanted $70 for fin repair....i said no again. i had allready spent $419. that was enough for me on the head.kz1k wrote:
1978 KZ1000A2
- kz1k
you got a link to what i need omr? im still far from putting the motor back together let alone doing the timing, but tips are tips."why did they put that nasty silver paint on there"...
1978 KZ1000A2
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- DoubleDub
- Visitor
Just slather that there assembly luuuube all over.
- kz1k
i dont remember the fins being damaged when it went out, but i may be wrong. he called me to tell me they were broken when he recieved it....oh wait....called me? they dont have phone customer service. yeah, i dont think ill send him anymore parts. and he offered to paint it, but f that.hmm, poor non-shiney finish and broken fins...sounds like pitstop gets a thumbs down!
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- z1kzonly
- Thank you received: 540
Hate to say it, but that is not glass bead!
That is an aggressive media. Looks like aluminum oxide or plain old silica sand!
I glass bead stuff all the time.
- kz1k
if you read....i said its probably been sandblasted. i wont be sending out my parts to psp anymore.Old Man Rock wrote:
1978 KZ1000A2
