- Thank you received: 2
KZ1K'S ENGINE PROJECT
- keith1
redlinecycle.com/Wire%20Harness.html
- keith1
Cheapest and most efficient aren't the same.
Cheapest is a roll of strip sandpaper from Harbor Freight. You can wrap it around the frame and sand to your hearts content. Will take a good amount of time, though.
that frame isnt bad......i d degrease the hell out of it, 3m scotchbrite it, and spray your favorite way......but thats just me...:dry:
- kz1k
- You Cant Fix Stupid!
www.autozone.com/autozone/accessories/Ru...entifier=660023_0_0_
1978 KZ1000A2
- keith1
- porchev914
- Thank you received: 19
FRANKEN Z!
- kz1k
www.autozone.com/autozone/accessories/Ru...entifier=660023_0_0_Aircraft Paint stripper in a can and some cheap paint brushes. Wear gloves and eye protection in a well ventilated area, it's NASTY stuff.
1978 KZ1000A2
- keith1
the bike has chips missing. fuck sanding it. i have spent too many hours sanding when i painted my 68 camaro. countless hours....sandpaper makes me cringe. a light once over, ok, but sandpaper and elbow grease plus hours of work is for the birds imo.
that will work.....but just make sure you cover that steel up quick and right.....bare metal and florida dont mix....
if you strip it and water it down and put primer on it...aint gonna work...i would think you are going to need some kind of acid etcher.....
- kz1k
ill strip it, water it down, clean it with acetone and hit it with primer.kz1k wrote:
1978 KZ1000A2
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- kz1k
1978 KZ1000A2
- testarossa
2004 ZX-10R
Angola, IN
- Thank you received: 2098
Could diy sand-blast, or have it done, before painting.
Might also consider diy soda-blasting.
