- Thank you received: 3
KZ1K'S ENGINE PROJECT
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- muddy1
- 1980 Kz1000 LTD B4
:dry:
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- keith1
- Thank you received: 2
- kz1k
- You Cant Fix Stupid!
cam bearings...you meen the bearings on the cam towers? no i did not get new ones. wet sand them with 1500?okay.....everybody settle down......i had pitstop do a head for me and thats how it was shipped......its fine.....the caps and cams are coming out again anyway.......did ya get new cam bearings?......if the old ones are serviceable,do em with 1000 grit or 1500 grit wet....its been a while, not sure....make sure everything is clean.......
1978 KZ1000A2
- kz1k
the bolts holding the cam towers were hand tight.Please don't tell me someone bolted cams even half way down in to a head! A gamble, are they alingned? in time? Sync?
Do you know how easy valves can tweek, bend? .001 of an inch and you loose your compression!
My opinion! Or did I miss something??:S
1978 KZ1000A2
- larrycavan
- Visitor
- DoubleDub
- Visitor
- keith1
yep.....there are two halves .....if you have anything dicernable by running your fingernail across them, they need some work.....pm Larry...although you didnt have him do your head, he will give you the scoop....he's good like that......
- larrycavan
- Visitor
Are you:
Hitting the hooch?
Spanking the pooch?
or cleaning gaskets ? :woohoo:
- porchev914
- Thank you received: 19
FRANKEN Z!
- larrycavan
- Visitor
Right angle die grinder & scuff pad kit
Base gaskets are the worst but with the studs removed it's a lot easier. Since I always go with APE studs they're out of the way anyway....
Any spots left come right off in the blasting cabinet.
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
