KZ1K'S MOTOR
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: KZ1K'S MOTOR
25 Sep 2010 14:38
#401684
i took the oil pan off. some small metal, but less than i thought. i found a piece of rubber....can you identify it?
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
25 Sep 2010 14:39
#401685
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
25 Sep 2010 14:40
#401686
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
25 Sep 2010 14:40 - 25 Sep 2010 14:41
#401687
1978 KZ1000A2
Last edit: 25 Sep 2010 14:41 by kz1k.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: KZ1K'S MOTOR
25 Sep 2010 14:42
#401688
cam chain tensioner/idler part
  • otakar
  • otakar's Avatar
Re: KZ1K'S MOTOR
25 Sep 2010 14:49
#401689
That looks like the rubber damper from the tensioner idler wheel. Most likely it was dropped in during assembly. It is not worth pulling the engine apart to pull out and it is a cheap part just to put in another one. What you found in the oil pan is all normal and for all practical purposes the engine is spotless inside.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • kz1k
Re: KZ1K'S MOTOR
25 Sep 2010 15:09 - 25 Sep 2010 15:20
#401696
ok so new piston rings, what should i do with my sleeves? 2 comes out a little, and 4 comes right out? find a set of jugs at the bike salvage, or buy larger sleeves?
then besides the rings, ill send the head out and have larry do a valve job.
1978 KZ1000A2
Last edit: 25 Sep 2010 15:20 by kz1k.
  • otakar
  • otakar's Avatar
Re: KZ1K'S MOTOR
25 Sep 2010 15:13 - 25 Sep 2010 15:16
#401698
You can buy those blocks on eBay for next to nothing. There are at least four sets on eBay right now between $50-$100. Any 1000 cylinder block from 1977-80 will fit.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 25 Sep 2010 15:16 by otakar.
  • kawsakiman
  • kawsakiman's Avatar
Re: KZ1K'S MOTOR
25 Sep 2010 16:32
#401744
i told you how to put the sleeves back in.
after you button up the top end they won't move anymore.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: KZ1K'S MOTOR
25 Sep 2010 17:19
#401760
you got the bike for free right? how about i just give ya $200.00 for it and solve your problem? B)
  • DoubleDub
  • DoubleDub's Avatar
Re: KZ1K'S MOTOR
25 Sep 2010 17:20
#401761
"to sink the sleeves back in the block go buy a cookie sheet, heat your oven to 400 degrees, flip the block over on the sheet and in about 15-20 minutes it will expand and the sleeve will fall into place. then just set it flush while still warm."
  • DoubleDub
Re: KZ1K'S MOTOR
25 Sep 2010 17:21
#401763
I'll go for $201.00! Let the bidding begin...
