KZ1K'S MOTOR
- kz1k
- You Cant Fix Stupid!
Re: KZ1K'S MOTOR
24 Sep 2010 19:52
1978 KZ1000A2
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 19:53
1978 KZ1000A2
- 9am53
- homebrew, and some bbq
Re: KZ1K'S MOTOR
24 Sep 2010 19:54
I think they look good, but I can't quite see them
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 20:01
yeah its the way they came out of my email....sorry.
1978 KZ1000A2
- 9am53
Re: KZ1K'S MOTOR
24 Sep 2010 20:06
i think you should get that motor for sure man, if you think he's not bullshitting you about it, and the comp is good and it turns freely then hell yeah. clean it up and you have a kz900 on your hands which is more than most people can say.
'84 GPz900r
'71 CB350
'71 CB350
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 20:44
9am53 wrote:
yeah i hear you man. gatta scrap up some change here so i can go get it. he is about 2 hours away, and until i even go there i need to have him do that compression test, and be willing to do one when i get there to verify the #'s. it seems he has been building these bikes for a while now. he retired in 1998.i think you should get that motor for sure man, if you think he's not bullshitting you about it, and the comp is good and it turns freely then hell yeah. clean it up and you have a kz900 on your hands which is more than most people can say.
1978 KZ1000A2
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 20:49 - 24 Sep 2010 21:31
if the 900 cc works out...what do you recommend i do with it? honestly...i think i am going to make it a drag bike. it doesnt need to the the fastest, most exspensive motor rebuild, but what are some ideas? if i bore the 900 motor can i use my 1000cc pistons, or will i have to buy pistons? vs buying new pistons prices...are they super exspensive?
1978 KZ1000A2
Last edit: 24 Sep 2010 21:31 by kz1k.
- DoubleDub
Re: KZ1K'S MOTOR
24 Sep 2010 22:03
The 903cc sleeves can be bored to accept the 1015cc pistons. Aftermarket pistons (i.e. Wiseco's) will give you more compression than the stock Kz1000's, but that's about the biggest difference. If you're looking to be cost effective and the engine has compression and you just want it to drive right now....then don't do anything. Just get it going.
- porchev914
Re: KZ1K'S MOTOR
24 Sep 2010 22:04
My short term recommendations would be to do nothing except get it running. Once you've got a runner, the sky's the limit! You can use the 1000 engine to build a hot rod while you ride the 900 engine around. At least thats what I'd do
FRANKEN Z!
- DoubleDub
Re: KZ1K'S MOTOR
24 Sep 2010 22:06
porchev914 wrote:
Good point- then you'd be able to ride and save up the money to make a decent hopped up motor. And the Kz1000 cylinders allow you to go quite a bit bigger than the Z1/Kz900 cylinders do without swapping sleeves.
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 22:18
DoubleDub wrote:
i just need to know if my block..cylinders are keepable.
ok, that sounds fine and dandy. but tell me...ok the cylinder sleeves are not pressed in my cylinders anymore. how would you go about fixing that, or is my block bad and not reusable? i was told that the sleeve is what acually gets bored, not the block, is that rue? and if it is true, is there a way to keep the block and get sleeves that might be a bit bigger to fit?porchev914 wrote:My short term recommendations would be to do nothing except get it running. Once you've got a runner, the sky's the limit! You can use the 1000 engine to build a hot rod while you ride the 900 engine around. At least thats what I'd do
1978 KZ1000A2
- porchev914
Re: KZ1K'S MOTOR
24 Sep 2010 22:26
In your case, I think I would just go with a 1200cc kit. That would replace the current sleeves and any apprehension you still have about them. I kinda wish I would have gone with a 1200. It would have made running FCR35's much easier...... the black and gold Yosh ones, drooooooooooooool :woohoo:
FRANKEN Z!
