KZ1K'S MOTOR
- kz1k
- You Cant Fix Stupid!
Re: KZ1K'S MOTOR
24 Sep 2010 10:18
chris said he built this bike from scratch....i just sent him pics of my bike and motor. he said he will do a compression test on the 900 motor. but if its worth it...ill send the entire bike out to him.....havnt decided yet.
kz1k wrote:
kz1k wrote:
1978 KZ1000A2
- TerryK
Re: KZ1K'S MOTOR
24 Sep 2010 10:45 - 24 Sep 2010 10:50
Just for your information, splitting the cases on a Z motor is less complicated than taking the top end off.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 24 Sep 2010 10:50 by TerryK.
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 10:47
TerryK wrote:
i was told that when you split a case the likelyness of it leaking is high.Just for you information, splitting the cases on a Z motor is less comprlicated than taking the top end off.
1978 KZ1000A2
- Kidkawie
- I bleed premix
Re: KZ1K'S MOTOR
24 Sep 2010 10:50
kz1k wrote:
Yeah, if you split it where it shouldn't be split. lol
TerryK wrote:i was told that when you split a case the likelyness of it leaking is high.Just for you information, splitting the cases on a Z motor is less comprlicated than taking the top end off.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- porchev914
Re: KZ1K'S MOTOR
24 Sep 2010 10:58
If the comps are good, and you can verify that, I don't think $300 is out of line for a complete Z1 engine. Just don't make any irreversable decisions when emotional. It may be frustrating now, but if you can hang in there. This "little" project will impact your life positively in more ways than one.
FRANKEN Z!
- porchev914
Re: KZ1K'S MOTOR
24 Sep 2010 11:01
Seriously, splitting the cases IS simpler than removing the top end, but I think a compete resurected engine would be best for your sanity Joe
FRANKEN Z!
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 11:15
porchev914 wrote:
waiting on the #'s from chris.
what makes it a Z1?If the comps are good, and you can verify that, I don't think $300 is out of line for a complete Z1 engine. Just don't make any irreversable decisions when emotional. It may be frustrating now, but if you can hang in there. This "little" project will impact your life positively in more ways than one.
1978 KZ1000A2
- DoubleDub
Re: KZ1K'S MOTOR
24 Sep 2010 11:29
I believe all the 900 (903cc) motors were the same. A Z1 motor is a Z1 motor because it came off of a Z1 bike. My Kz900 motor has the same crank, pistons, cylinders, head, etc. There were some minor differences, carbs went from 28mm to 26mm (and I'm told got easier to work with), automatic chain oiler, and a few others beyond just the appearance of the bikes. There's a model history section on this site if you poke around a little.
- porchev914
Re: KZ1K'S MOTOR
24 Sep 2010 11:37
Honestly, in '74, I don't know if they had separated the Z1 and Kz900. I believe if the engine serial # starts with Z1, then it's at least a Z1 case :laugh: Other than that, the only difference I know of is the crank.
FRANKEN Z!
- kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 11:45
good to know. man i have learned so much just in a week. i got a lot more to learn too. lol
i am still undecieded about cracking the case.....i dont want to just keep taking shit apart when i am waiting to hear about another motor. twiddling thumbs..hehe
1978 KZ1000A2
- DoubleDub
Re: KZ1K'S MOTOR
24 Sep 2010 14:16
porchev914 wrote:
Negative - the Kz900 motors all start with similar serials (Z1E). The engines are basically identical, including the crank. Wasn't until the Kz1000 that the crank was beefed up.
- MFolks
Re: KZ1K'S MOTOR
24 Sep 2010 14:30
Have you read this information(not sure if you've got this before):
www.aperaceparts.com/tech/techkz1000.html
