KZ1K'S MOTOR
Re: KZ1K'S MOTOR
24 Sep 2010 14:37
#401484
Kidkawie wrote:
kz1k wrote:
TerryK wrote:
Just for you information, splitting the cases on a Z motor is less comprlicated than taking the top end off.
i was told that when you split a case the likelyness of it leaking is high.
Yeah, if you split it where it shouldn't be split. lol
So maybe he shouldn't use a genuine Kawasaki case splitter as pictured?
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: KZ1K'S MOTOR
24 Sep 2010 14:52
#401488
HA, from what I've seen of those Kawasaki power tools I don't think it could even get through a case before burning out!
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: KZ1K'S MOTOR
24 Sep 2010 18:28
#401516
this is one of chris's bikes he built.......still waiting on pics of the 900 motor and maybe a compression test this weekend.
with that cylinder sleeve sliding out, is the top end salvagable?
1978 KZ1000A2
  • TerryK
  • TerryK's Avatar
Re: KZ1K'S MOTOR
24 Sep 2010 18:43
#401521
Yes it's salvageable. Press it back in and you're golden.
Why don't you at least flip the engine over and pull the oil pan? Even that will tell you volumes about the condition of the lower end.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 18:58 - 24 Sep 2010 18:58
#401525
i drained the oil and need to wait till tomm to put it in the sun light to see if there is a ton on metal.....what will i see when i drop the oil pan?
i didnt know they had oil pan?
1978 KZ1000A2
Last edit: 24 Sep 2010 18:58 by kz1k.
Re: KZ1K'S MOTOR
24 Sep 2010 19:08 - 24 Sep 2010 19:13
#401528
kawasaki.com has lots of helpful info and parts diagrams. :cheer:
Click here > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
For example, here's the 1978 KZ1000 oil pan:
Good Fortune! :)
Last edit: 24 Sep 2010 19:13 by Patton.
  • kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 19:48
#401531
i talked to chris and he said that the oil pan bolts are magnetic and any metal the block would stick to the bolt and come out when removed.
anyway here is the 900 he has for sale for $300. he is going to do a comp test for me when he gets a chance.
these are the bikes he built.....i almost wanna drop my bike off and let him go nuts, but i want to do the work on my bike for my own good and ease on my pockets.
what do you guys think?
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 19:49
#401532
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 19:49
#401533
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 19:50
#401534
heres chris's bikes...
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 19:51
#401535
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
24 Sep 2010 19:52
#401536
1978 KZ1000A2
