- Thank you received: 225
I want a Kerker
- Old Man Rock
25 Jan 2010 17:07 #344538
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic I want a Kerker
That last clip has to be Arizona, no doubt.....
Uhm Roy, is that your bike with the purdy pink frame?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
25 Jan 2010 17:14 #344543
by keith1
Replied by keith1 on topic I want a Kerker
roy,
not a war starter, but neither of those clips is giving me wood for a kerker.....my vance and hines with the comp baffle with the packing removed sounds way better than those.....unfortunately you ll have to take my word for it untill its back together again...
- roy-b-boy-b
- Thank you received: 103
25 Jan 2010 17:20 #344545
by roy-b-boy-b
Replied by roy-b-boy-b on topic I want a Kerker
I'm just trying to find diffrent exhaust. Roy
- keith1
25 Jan 2010 17:25 #344547
by keith1
im with ya....post away
- roy-b-boy-b
25 Jan 2010 17:30 #344548
by roy-b-boy-b
- roy-b-boy-b
25 Jan 2010 17:34 #344550
by roy-b-boy-b
Macs are hard to find!!
- roy-b-boy-b
25 Jan 2010 17:36 #344552
by roy-b-boy-b
My favorite. :laugh:
- trianglelaguna
- Thank you received: 235
25 Jan 2010 22:20 #344603
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic I want a Kerker
(youtube)
1976 KZ900
2003 ZX12R
2007 FZ1000
- Old Man Rock
26 Jan 2010 04:46 #344610
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
River... "Dents in the bottom are routine? ".... You may want to do some further research into the "Ground Clearance" issues for based on what your hearing, there's several other variables that occur here...
NOTE: Not trying to tell you one way or another or start a flame war here with the others... Read on...
This occurs on all 4 to 1 exhaust systems regardless who makes it.... Here's why I say this as fact...
In my research I'm doing for fabbing my own exhaust, the math for designing a TUNED 4-1 KZ900/1000 header/exhaust system depicts 1.5" O.D. 30-34" Primary piping feed into a 4-1 collector that resides under the oil pan area...
In all the manufactures using a 4-1 design "Megaphone", to allow access to drain/oil filters they use a 2 over 2 collector. See attached image, top right. Something similar to this 2 over 2 design for 1.5" inlets or some variation of it..
With the piping being 1.5" OD and the collector inlet I.D. size being slightly above, there's only so much room under the engine case thus ground clearance that can be accomplished.
The tighter they design the piping to the lower engine oil pan and frame, the more clearance you'll have but there's truly only so much that can be done about this...
Again, all 4-1 systems will have this issue, no doubt, no way around it. Same time, also will depend on a few variables such as what type of road surface (ruts, rocks etc), rider weights and suspension setups... MXing a KZ :blink: when this scraping occurs. Again, they all do it...
As in my design, I'm thinking the FLAT 4 into 1 concept for additional clearances. Especially in my KZ build ZX636 conversion where I only have 17" tires. Normal KZ's run 19" front, 18" rear so I lost some considerable clearance in that alone.
I only have 4-5" clearance and I've only scraped once... Like a dumbass, forgot about this fact while driving over a speed bump... Thankfully, was driving slow and only scrapped a little versus dent... Now I avoid or go slow/at an angle to speed bumps, hasn't occurred since.
Hope this help out a little in this matter regarding ground clearances of a 4-1 exhaust systems...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- TerryK
- Thank you received: 3
26 Jan 2010 10:17 #344673
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic I want a Kerker
With the mods I have, I find the Kerker to be a FAR better system for the street that the Wieseco (V&H) I'm running right now. Way more mid range and the roll on acceleration is much better that the V&H. I also have a very slight 3-4k burble that I just cant jet out, but when I put a Kerker on it was gone.
Anyone have a nice used Kerker for a broke Canadian?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Old Man Rock
26 Jan 2010 10:34 #344676
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
" 3-4k burble"... Yup, I believe that to be the flat spot mentioned in sevral of the documents i have foound in my research...
It also has to do with the primary pipe diameter and lengths...!
As I'm finding out... For a tuned system to be dialed in for YOUR specific KZ or engine for that matter, displacement and cam exhaust BBDC are required...
As in my KZ900, my cams are designed for low to mid range performance. @ 5800rpm and in my clacs I'd want 1.5" OD pipe @ 30" for tuned perfection for my build of mid range power band... Putting a longer primary @ 34" would defeat the build... Would it work and run sure but.....
As will be posted soon (Yoshi posting), I have taken measurements from several exhaust I have and in provided measurements from others, diameters and lengths place a key importance for your builds...
I'm putting the final touches on the write up, should have it posted in a couple of days....
Truly interesting findings on how this all works hand in hand... It also brings up the JET issues have where works great for me but not for you....
The puzzle pieces are falling inot place...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- roy-b-boy-b
26 Jan 2010 14:50 - 26 Jan 2010 14:51 #344725
by roy-b-boy-b
I'll be tuned in !! :laugh:
Here is my old kerker and Mac. I actually slipped the Kerker over the Mac. Roy
Last edit: 26 Jan 2010 14:51 by roy-b-boy-b.
