I want a Kerker
- otakar
No you do not use them because they most likely fall out and if you will notice, they won't even fit. These original pipes were made for Yoshi by MAC.Question....
On these old Yosh pipe headers, finding the exhaust flanges are tacked into place...
With this in mind, do you still require the split collars?
OMR
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
Kawi whipped up a newer design with the pipe; it has cross overs from 1 to 4 and 2 to 3 very shortly after the exhaust ports. I replaced a mac 4 into 1 and had to go up 2 more jet sizes (The bike was already 2 sizes over for the mac pipe and emgo pods) and I still had a bad flat spot from 7k on up (the last main jets must be close because with the choke on it pulled hard to the red).
The gringo and a few other folks have done this swap and everyone who has done it seems to like it.
New = better in my book; to much has changed since disco and leisure suits ruled the world.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- hardr0ck68
Shortly after changing to the zr7-s pipe I still had the sooty plugs, so I used the WG coil mod, and then I found bone white plugs; 3 main jet sizes later and I am still finding it runs better over 7,000 rpm with the choke pulled. To me that says I need a larger still main jet. I installed a wide-band o2 sensor; but the over worked charging system cannot cope with the amp's required to run it properly. Something I will correct with my winter project.
I know some folks love looking at spark plugs for hours and pretending to be gear-head sages of spark plug tech; but I loath jetting changes (perfecting instead to be riding!) and would rather be reading a nudie mag than a spark plug. I like numbers! and the wide-band will give them to me.
a pic of the bike when I bought it (I has already started tearing it down here)
1977 kz650 c1
- hardr0ck68
1977 kz650 c1
- hardr0ck68
1977 kz650 c1
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Thank you received: 2829
- will61310
- Thank you received: 6
Didnt Mac make pipes for Bassani for a while??MAC is one of the best flowing pipes around. That is why you had to go up so many sizes.
...1980 LTD 1000...
- trianglelaguna
- Thank you received: 235
will61310 wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- PLUMMEN
- Thank you received: 104
