- Thank you received: 3
I want a Kerker
- TerryK
I'll be tuned in !! :laugh:
Here is my old kerker and Mac. I actually slipped the Kerker over the Mac. Roy
You have the rest of that Kerker Roy?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- roy-b-boy-b
- Thank you received: 103
- Old Man Rock
- Thank you received: 225
Can I get you to take some measurements of the MAC pipe when you get a chance..... Similar to these measurements...
Bet from exhaust port down to 4-1 collector, ~ 34"
Thanks....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- roy-b-boy-b
- davel
I also have a very slight 3-4k burble that I just cant jet out, but when I put a Kerker on it was gone.
Are you running a baffle? If so, what size?
- hardr0ck68
- Who put the what in the where?
Keep the header pipe ID around 1.16x exhaust valve open area (valve circumference x lift x number of exhaust valves). This will keep your exhaust gasses moving along as a reasonable speed without being restrictive. <--- (as recommended by Mr. Cameron)
4-2-1 will work well to keep you from having a flat spot or drop in torque at mid-range rpm's. They will not produce as much top end torque as a well designed 4-1, but you will show a much smoother torque curve if designed correctly.
I have found 3 or 4 differing formulas used to determine "optimal" performance. These formulas all revolve around the length of header BEFORE A JUNCTION to give maximum "boost" from the negative wave created by the junction... any length you chose will however create a positive wave at some other RPM, which will cause a drop in torque.
You could use an actuator off of a sport bike and open a secondary chamber at varying rpm's, this will insure you are always making use of the negative wave and avoiding the positive.
Exhaust tuning is fascinating stuff, glad to see you stepping forward into the 21st century!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- Leather
- Thank you received: 2098
Click here > Out, Damn'ed Dent!
Good Luck!
- PLUMMEN
- Thank you received: 104
- trianglelaguna
- Thank you received: 235
(youtube)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- roy-b-boy-b
- Old Man Rock
Naw KZ brother, don't go there.... If you haven't figured us all out yet, we're somewhat opinionated here... :huh: :dry: :laugh:
As you mentioned, nothing wrong with fixing her up until the research or $$$ for what you want are there.
Me, I'm no way giving up my Kerker w/1.5" comp baffle..
The "design & fab my own pipe is for the next KZ build and to just see if I can do it effectively. Meaning place the desired power band where I want it following the lines of that beautiful curved Yoshi header... DROOL!
But from what I have come to realize, there's a hell of a lot more to a pipe deign than sound & looks & power & increases I just didn't fully understand.
Example, pending my engine build displacements and cam selection, I'd find a pipe with longer or shorter primaries & exhaust lengths to fit more closer to my engine build...
This is where the true power comes to life in our builds.
We can do all this, all that in the engine & head but if we choose the wrong exhaust, that power won't come through to desired expectations.
For most manufacturers out there, they're build their exhaust systems to an average cc displacement (903/1015) and cam selection (70BDC/30ADC)for the KZ series... Based on the exhaust measurements I've taken, they're all around this 7000 peak torque range...
In my cam selection, I'd want to shift the power band more towards the 6000-6500rpm range... Henceforth "Tuned Exhaust" for my build! Yeah baby!
Anyhoot, don't take us Neanderthals too serious for this is just how we are here....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
