78 KZ 1000 build
  • Formula264
  • Formula264's Avatar Topic Author
Re: 78 KZ 1000 build
15 Jun 2026 18:03 - 15 Jun 2026 18:06
#924931
Last edit: 15 Jun 2026 18:06 by Formula264.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
The following user(s) said Thank You: Formula264
  • Formula264
16 Jun 2026 08:28
#924949
Link to first fire up of the bike.. photos.app.goo.gl/do4j8gRVq7hLa83y5
  • Formula264
23 Jun 2026 20:46
#925232
 Going to get the exhaust finished out Thursday and a few other fab things. cutting off the rear footpeg mounts and the center stand mounts. Also the rear shock mounts extended for better geometry.
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
24 Jun 2026 08:43
#925248
You might want to keep the center stand mounts so you can put the stand on to service the bike.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Formula264
24 Jun 2026 13:00
#925254
I'm thinking the rear wheel lift/stand should serve that purpose?
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
24 Jun 2026 14:54
#925259
The main stand would allow swingarm removal if necessary (my lift uses the main stand mounts as a pick up point)
  • Formula264
25 Jun 2026 10:23
#925286
Point taken. I may keep them on there to use as a lift point.
  • Formula264
26 Jun 2026 11:19 - 26 Jun 2026 11:21
#925320
Off to get the exhaust finished out as well as the shock studs lengthened and rear foot peg mounts removed. I believe he is going to fab a chain guard as well on a 3D printer. Before  pic, will post an after in a few days
photos.app.goo.gl/t1JM3qhsuGiRk35E8
Last edit: 26 Jun 2026 11:21 by Formula264.
  • Formula264
02 Aug 2026 17:47
#926426
Should have it back in my hands in a few days. Just a few more little things and I believe I am there.
  • Formula264
11 Aug 2026 10:23
#926644
Have the rest of the exhaust done as well as the rear peg mounts removed and upper shock studs lengthened. I have to modify the swingarm more to move to the left as the rear tire is not centered but the chain is in alignment. It will require the counter to be moved outboard a little more and the rear sprocket to be moved more inboard. I am presuming that an offset rear sprocket is available for a ZRX. After that the last thing is to reseal the forks and it should be good to go..
  • Formula264
11 Aug 2026 10:26
#926645
