78 KZ 1000 build
  • TexasKZ
  • TexasKZ's Avatar
Re: 78 KZ 1000 build
11 Aug 2026 10:48
#926646
FYI, the rear tire does not need to be perfectly centered. The ZRX1200 came from the factory with an offset rear wheel, about 10mm as I recall. I understand that several HD models also have offset rear wheels.
The following user(s) said Thank You: Formula264
  • Formula264
  • Formula264's Avatar Topic Author
11 Aug 2026 17:41
#926651
Thanks for that info. It seems to be noticably off center. IDK, it is a lot closer to the right shock than it is to the left one, just doesn't look quite right. I have ridden it about a half mile with no noticable handling problems but have not done any real testing.
