And finally, Wookie's 82 begins !
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
  • Moderator
Re: And finally, Wookie's 82 begins !
09 Nov 2025 08:03
#918893
Thanks Joe, I have tried to use this project to push myself to learn new skills and also show that you "can have nice" without spending the earth if you put the effort in. I reckon when all done I will have spent around what you pay (in the UK at least) for a tired but useable 70's "Z"
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
09 Nov 2025 08:10
#918894
It all looks great to me. Isn't painting in a shed fun!
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
09 Nov 2025 08:23 - 09 Nov 2025 08:23
#918896
...and I think you did a great job!
...And constantly counting or calculating money is boring, isn't it? The result is what counts, not the total investment!
(For me personally, it's always important that everything works for me, that it functions well and correctly, and that I like it. I don't usually follow the crowd or the opinions of others, but then again, I'm not really a herd animal anyway ;-)
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Last edit: 09 Nov 2025 08:23 by MFP-Joe.
  • Stereordinary
  • Stereordinary's Avatar
09 Nov 2025 09:00
#918898
The paint looks great Wookie!
A breeze from the west.
  • Wookie58
  • Moderator
  • Moderator
09 Nov 2025 09:12
#918900
In a warped, masochistic kind of way
  • gd4now
  • gd4now's Avatar
09 Nov 2025 10:14
#918901
I agree Wookie, "In a warped, masochistic kind of way". One must work with what one has access to. I have painted a couple of cars in an old shed/garage and understand just what you have experienced. There is an old saying that goes something like necessity is the mother of invention? If one needs to paint inside instead of outside (which has it own set of issues) and a shed is all that you have then you paint in a shed with all that it entails.As I said the end result looks great to me and now you know you can do so in a shed.
1977 KZ650 B1
  • moizeau
  • moizeau's Avatar
09 Nov 2025 11:09
#918902
Potential BOTM there Guy, nice job
  • kimchella
  • kimchella's Avatar
09 Nov 2025 11:50
#918903
Ditto Joe….
There is always a great satisfaction when you do something you have not done before, and to turn out a job that also looks great is a top shelf achievement.
Great job Guy.
KZ650B1 frame number 225
New Zealand
  • Injected
  • Injected's Avatar
09 Nov 2025 12:46 - 09 Nov 2025 12:48
#918904
Looks like a fine job you did there! I find its always more satisfying to say you did it on your own no matter how it turns out.
How was the temperature and humidity in your "booth"?
I recently did a fender repair paint job on a car in my garage but it was about 17C in there, today we had our first snowfall (5cm) that's sticking to the grass :(
1978 KZ650B2 modified project
Last edit: 09 Nov 2025 12:48 by Injected. Reason: sp
  • Bloobaba
  • Bloobaba's Avatar
09 Nov 2025 13:27
#918905
If you want to improve your skills, I have a set to paint for my Z (like the one in the thumbnail). 😄
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
  • Wookie58
  • Moderator
  • Moderator
09 Nov 2025 14:51
#918906
  • Wookie58
  • Moderator
  • Moderator
09 Nov 2025 14:59 - 09 Nov 2025 15:01
#918908
With the water-based colours temp was around 20c (around 11c outside and raining all week) not sure about the humidity but would have been high initially as water-based relays on air flow to flash off. The only way I could create flow was to prop the side door open (allowing damp air in) Once I got the de-humidifier in there (around 65%) the flash off reduced from a couple of hours to around 40mins. With the clear I heated to around 20c then turned the heater off (three bar electric patio heater so would have blown the place up) once the air cleared after shooting the clear I put the heater back on for the rest of the day
Last edit: 09 Nov 2025 15:01 by Wookie58.
The following user(s) said Thank You: Injected
