And finally, Wookie's 82 begins !
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
  • Moderator
Re: And finally, Wookie's 82 begins !
11 Jan 2026 14:26
#920532
I've had a cold day on the lathe today (2 degrees) making push fit plastic plugs ready for blasting next week :) I like to minimise as much as possible blast media getting inside
The following user(s) said Thank You: Injected, MFP-Joe
  • Injected
  • Injected's Avatar
11 Jan 2026 19:55 - 11 Jan 2026 19:56
#920547
I did hear you guys had a cold spell over there, good for you that you could still get some work in on your project.
It was -3C here today with blowing snow, shoveled about 6CM of snow from the drive. No work on anything today other than a cup of tea with some biscuits :)
1978 KZ650B2 modified project
Last edit: 11 Jan 2026 19:56 by Injected. Reason: sp
The following user(s) said Thank You: asphalt900, Wookie58
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
12 Jan 2026 01:12
#920555
Hi Wookie,
good Idea and job, ... take care before, is better than a pottfull of angry after!
BTW: Last 2 nights it was -12°  to-15°C here, day was -9°C...but i´ve had handled all the snow here in front of the garages, was about 40cm high on 10x11 meters..
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • Wookie58
  • Moderator
  • Moderator
12 Jan 2026 01:20
#920556
Hi Wookie,
We had it easy, only -5 here on Friday and around 10cm of snow :)
  • asphalt900
  • asphalt900's Avatar
12 Jan 2026 02:47
#920561
You cats and your sub-zero temperatures, getting the chills just thinking of it, burrr. Wookie i see you took the butterfly shafts out, are your one-way seals (2-per shaft) still supple and lip not cracked when squeezed? Kawasaki never offered them but Suzuki did, just in case. Personally when i blast carbs i don't concern myself with media getting inside. Just make sure the galleys are dry before doing it, don't want it to cake-up. I use a power washer with water to blast off all the stuff. With 1000psi of water flowing nothing escapes removal. You can witness flow of water coming out of the pilot bypass and air correction jets also choke so you can easily tell if something isn't right. Of course considering your outside temps this won't be practical, sorry.
  • Wookie58
  • Moderator
  • Moderator
12 Jan 2026 03:18
#920562
Thanks Clay, the seals are a little hard and also really loose on the shafts (no surprise after 40 years and would probably create air leak issues if left) I have been on that merry go round ref seals (apparently they used to be available for the later "P" models) I read that Yamaha seals fit but then I found a post on a Yamaha forum that (as you say) suggested the Suzuki seals also fit. With me being "cheap" the Suzuki parts at half the price of the Yamaha ones looked really attractive so that is what I ordered last week (should be here in the coming days) The body's have had a good soak in the ultrasonic bath and been blown out with compressed air (which I will do again after blasting) I intend to give them a coat of Cerekote aluminium clear which should make them easier to keep clean afterwards
  • Injected
  • Injected's Avatar
18 Jan 2026 10:25 - 18 Jan 2026 10:39
#920740
From earlier in your thread :
28 Sep 2025 14:20
"I have also used "shielding on the looms where they run over the coils so that hopefully the EMF from the coils doesn't cause "instrument or LED flicker"
I was wondering if you covered the tinned copper sheath with a black PVC sheath, or its just bundled to hide the "silver"?
I ask because I am looking to use some tinned copper wire covering on a portable AFR meter I have, and also use the same on a upcoming DFI build.
Not too crazy on the silver as its stands out too much next to a stock wire harness.
Fantastic build thread so far!
Last edit: 18 Jan 2026 10:39 by Injected. Reason: more info
  • Wookie58
  • Moderator
  • Moderator
18 Jan 2026 10:58
#920742
28 Sep 2025 14:20
The black "braided" sleeve is over the top of the silver to keep it all looking subtle :)
  • Injected
  • Injected's Avatar
18 Jan 2026 11:34
#920744
Thanks for clarifying that.
I sort of thought that is what you had done, but just wanted to double check in case there was some black colored sheath I was unaware of.
I think I need to do this to my AEM AFR meter wiring as it goes from the handle bar over the coils to the back of the stock wire harness to get power.
Not really sure yet on the DFI build as I reviewed my mockup pics and the majority of the wiring to the ECU is contained under the battery box and all the sensor wires are under and to the back of the coils. The gauges on that build are a Acewell unit that has been modified to plug into the stock harness in the headlamp shell.
  • Wookie58
  • Moderator
  • Moderator
18 Jan 2026 12:53
#920748
To be fair it may be an "extravagance" but wasn't expensive, I have speedo and tach signals for the ZX6R clocks, the data wire from my narrow band lambda sensor (lambda 1 is 200mv - 800mv so any induced voltage will effect the reading) and a "lin-bus" data wire from a unit in the front connector station to the Axel Joost control box (handlebar switches operate the D-box via a single wire) all of which run directly on top of the coils. During this build I have tried to anticipate potential issues and resolve along the way (maybe :))
  • rich67
  • rich67's Avatar
20 Jan 2026 22:30
#920794
Wookie , I have been following your build for some time now, I have to say I this is one of the best builds I've seen. I can see your attention to detail in everything, and everything about this build is amazing. I used the expandable conduit as well for my wiring it looks so clean, can't wait to see the finished bike, it's a Work of art, Cheers to bud
The following user(s) said Thank You: Wookie58, Quofan
  • Wookie58
  • Moderator
  • Moderator
25 Jan 2026 10:19
#920940
Another cold weekend in the garage over, I got my carbs back from the blaster at the start of the week and dropped off my exhaust which should be ready tomorrow. I can't speak highly enough of Shawn at "Vapourshine" he does great work with a quick turnaround for a very fair price :) I have given the bodies 3 good coats of "Cerekote" aluminium clear. Time will tell how that works out but the brand have a good name so I am hopeful it will make them easy to keep clean for a good while to come.
The following user(s) said Thank You: Nessism, chopper1963, Dragbike_Mike, Stereordinary, Quofan
