And finally, Wookie's 82 begins !
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
  • Moderator
Re: And finally, Wookie's 82 begins !
29 Sep 2025 00:02
#917728
That is looking awesome Guy, makes all of the hours banging your head worth it.
Thanks Rich, definitely starting to see some "light at the end of the tunnel"
  • Wookie58
  • Moderator
  • Moderator
29 Sep 2025 00:04
#917729
Hey Guy, everything looks very clean and tidy, you're obviously a very good electrician!
Thanks Joe, electrics for me are like machining for you (it's how I paid my mortgage for many years)
  • Wookie58
  • Moderator
  • Moderator
29 Sep 2025 00:08
#917730
Extraordinary electrical work!  Best I've seen on a custom bike!
Thanks Ed, given how much I have to say about electrics I thought I best "pull out the stops" and not "half ass" it :)
  • Wookie58
  • Moderator
  • Moderator
29 Sep 2025 00:15
#917731
Wow, that looks absolutely fantastic Guy. Looks better than factory.
Have you made any progress on the engine yet or have you been tied up with the electrics?
If you need any help just shout. Always happy to come over to you.
You are welcome anytime buddy. Not started the motor yet (I don't like to just pile in and pull everything apart at the same time, that's how things go wrong !!) I think finishing up the bodywork and paint will be next - it was my plan to do that last but, the way the weather is changing if I'm not careful it will be "too cold" to paint soon without the risk of "blooming"
The following user(s) said Thank You: Quofan
  • TexasKZ
  • TexasKZ's Avatar
29 Sep 2025 06:40
#917735
No worries here, I have half-assed covered for you..........
  • Wookie58
  • Moderator
  • Moderator
29 Sep 2025 06:45
#917736
  • Nessism
  • Nessism's Avatar
29 Sep 2025 09:04
#917740
Hey Guy,
On the connectors without a wire installed, do you use a dummy plug to block water entry?  That was a requirement in the aerospace industry that I used to work in.  Without a plug, water can enter through holes in the rubber sealing grommets inside the connectors.
  • Wookie58
  • Moderator
  • Moderator
29 Sep 2025 09:08 - 29 Sep 2025 09:10
#917741
Hey Guy,
Good spot Ed, yes I will - there is only the one 4 pin that will be empty (one is for the fuel level sensor in the tank and the ones on the side are for the engine wiring (once I have an engine in it  ) will need to find something for the few spare locations in the plugs I am using
Last edit: 29 Sep 2025 09:10 by Wookie58.
  • Nessism
  • Nessism's Avatar
29 Sep 2025 09:58
#917744
In aerospace, plugs like these are used.  Sometimes, depending on the connector, the plug is installed from the backside.
  • TexasKZ
  • TexasKZ's Avatar
01 Oct 2025 06:09
#917783
I bet a titanium megaphone system would look mighty fine on this build.
japan.webike.net/products/26227084.html?...tm_campaign=20250929
  • Wookie58
  • Moderator
  • Moderator
01 Oct 2025 13:12
#917788
If somebody at Harris is bothered by having the company name on that exhaust system, they should be taken out back and slapped severely.
I doubt seriously if the company ever produced something that nice.
It's a nice looking piece Texas but the exhaust train has left the station. I will stick with what I have for 1/10th of the price :)
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
07 Oct 2025 10:03
#917928
Hi Guy,
I took the time today to read through your entire build report. I'm extremely impressed by your craftsmanship and your design ideas. I particularly liked the design of the side covers. Great work on the technology, modifications, and design! This will be a real showstopper. Go on this way, ...and i`ll repeat: Phantastic work!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
