And finally, Wookie's 82 begins !
Re: And finally, Wookie's 82 begins !
07 Oct 2025 10:47Thanks Joe, high praise indeed. There are a lot of firsts for me in this build (using a metal lathe, working with plastics etc) I think in the main it comes down to having an idea and going for it without being scared of it going wrong (most mistakes are recoverable)Hi Guy,
I took the time today to read through your entire build report. I'm extremely impressed by your craftsmanship and your design ideas. I particularly liked the design of the side covers. Great work on the technology, modifications, and design! This will be a real showstopper. Go on this way, ...and i`ll repeat: Phantastic work!
- MFP-Joe
07 Oct 2025 11:56
Yes, Guy, I completely agree with you, you just have to tackle the things you have in mind, the rest is mostly learning by doing, whenever i´ve had some ideas, i just ry to find a solution to fix it.
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
25 Oct 2025 12:20
So for the last couple of days I have been pushing on with getting ready for paint (was going to di it last but everything else has taken so long the weather will be changing soon and it will be too cold) one job I have been putting off was the "manual tap" conversion which is now done. Tomorrow will be POR15 time. I know there are differing views on tank liners but with the amount of welding I have done with the petcock and the filler there is a possibility of a "pin hole" in a weld somewhere and I really don't want the paint to start pickling from fuel vapour
The following user(s) said Thank You: MFP-Joe, Quofan
25 Oct 2025 14:16 - 25 Oct 2025 14:45
Hey Guy,
Forgive me for commenting if you are well versed on the POR-15 coating process, but just wanted to share a thought on how to get good results, in case you haven't done it before.
It goes without saying that you want to derust to the extent possible. Swish around the paint, and coat all surfaces, focusing on the backbone hump and top, then dump out the excess. Thing I've noticed, is that even after dumping out all you can, there will still be a good bit of paint remaining in the tank. What I do is keep the puddle moving, until it hardens up. It will take about 30 minutes. During that time, you can get two extra coats on the metal. The first coat will start to harden, so when you go back over it, you will deposit another layer. In the end, you will have a really nice thick coating inside the tank. Por-15 is good stuff!
Last edit: 25 Oct 2025 14:45 by Nessism.
The following user(s) said Thank You: MFP-Joe, sf4t7
25 Oct 2025 15:15
Thanks Ed, I’m a POR virgin so this advice is pure gold
29 Oct 2025 08:45
Well "it's happening" !! the POR-15 seems to have gone OK best I can tell (thanks Ed) now the primer is on so over the next couple of days I hope the "paint gods" are smiling on me. Never done multiple colours or used "water-based" paint (only ever used cellulose) so who knows what will happen ?
The following user(s) said Thank You: Injected, Nessism, Quofan
03 Nov 2025 09:40 - 03 Nov 2025 09:46
Well, love it or hate it the colour is on
this has been the most stressful part of the build so far. I had a clear vision of what I wanted the bike to be but when it came to colour I can't count how many times I changed my mind. I knew I didn't one a single colour but when it came to graphics most of my ideas just wouldn't have worked. Because of the heights of the nose cone and seat unit in relation to the tank trying to come up with something the flowed wasn't working for me. In the end I went with Howards suggestion of a scheme from a "Z900rs cafe" (just changed the colours and layout slightly.
) and so the journey began
Day 1: laid on the white base coat and stood back to admire my handywork - it was about now that it started "running" like a bastard all over the place !!! I'm sure this was a combination of my heavy handed novice painter skills but also, this is water based paint and it pissed with rain all week. For water based to dry it needs air flow, in my garage that means propping the door open a little (not ideal when it's raining and you want low humidity)
Day 2: flatted out the runs from day 1 and then I had to go to an open day at my grandsons new college so no time to repaint the white. I did however go to my daughters house and reclaim my de-humidifier.
Day 3: Dehumidifier and heater on, dialled down the gun and re-shot the white - success
Day 4: many hours of masking then laid down the champagne gold line between the white and the anthracite grey. masked the gold line and laid down the grey (including a "drop coat" to even the metallic") Left it for an hour and removed the masking (didn't want to leave the tape on overnight) - motherf*^@ker - looks like I was impatient when masking the gold as some lifted with the tape !!!!!!!!!!!!!!
Day 5: More masking and laid down the Porsche orange - peeled the tape and all good. Because of the delays I need to wait until the weekend to shoot the 2K clear but that gives me time to do some remedial work on the gold stripe. I think in hindsight going for a four colour base with my limited experience, the weather etc was maybe "foolish" but hey "what's the worst that can happen ?" The base has a matt finish so hopefully when the clear goes on it should pop. I don't like waiting so long to lay down the clear but I am back at work now and the evenings are too cold (not leaving an electric heater on in the garage overnight)
Last edit: 03 Nov 2025 09:46 by Wookie58.
The following user(s) said Thank You: Injected, Nessism, MFP-Joe, sf4t7, Formula264, kimchella
- MFP-Joe
03 Nov 2025 10:22
..and I repeat myself when I say: You have many talents, Guy!
..based on your designed side panels, I had already suspected that you had taken your cue from the side panels of the RS900.
n any case, really good work!! Thumbs up!!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
- Bobf
- KZ1000A3A
03 Nov 2025 20:28
Haven't been on the forum in some time. Really nice to see your progress. Paint is looking sharp!
EKKAWI
1976 KZ400D, 1977 KZ1000A1, 1976 KH400, 1979 XS400, 1980 KZ550A, 1980 KZ750E, 1983 GPZ550,1979 KZ1000B LTD, 1986 ZG1000 Concours,1982 XS650 Turbo,KZ1000C, KZ1000P,1978 KZ650C (×2),2003 BMW R1150RT
2014 BMW R1200RT (Current ride)
1971 Norton 750 Commando
1979 KZ1000A3A MKII (Present project)
- Bloobaba
03 Nov 2025 21:34
Wow, superb! It reminds me of the colors on my GPZ900, Ebony - Red Firecracker. 👍✌️
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
09 Nov 2025 07:34
I have broken my "2K cherry" today
, clear is on and I am really happy. There are a few "dust nibs" in it which I guess is to be expected painting in a shed but I will sand and buff them out once it is fully dried. Is it perfect ? - no it isn't but I think for a "$250" paint job applied in a shed by a novice it's acceptable to me for a rider (this is no show pony) I'm not convinced that if I had outsourced it to a professional that it would be $1k better ? I'll let you guys be the judge
The following user(s) said Thank You: ThatGPzGuy, Nessism, MFP-Joe, sf4t7, Formula264, kimchella
- MFP-Joe
09 Nov 2025 07:54
To me, it looks fantastic in the pictures!...And only you can decide whether you're happy with it or not! I always think: if you're satisfied with something you made yourself, that's satisfying enough, or you have to spend a lot more money and have it done professionally!
(Or another more expensive option is to practice until you're perfect
You can be proud of your work, Guy!!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
The following user(s) said Thank You: Wookie58, kimchella
