Starting a rusty '82 KZ750
- Tvag06
Re: Starting a rusty '82 KZ750
17 Jul 2019 10:56Tvag06 wrote:TexasKZ wrote: Or a loose rear axle
I think the castle nut needs some tightening. Thanks!
that did it
'80 KZ440D - Stripped for rebuild -
kzrider.com/kunena/11-projects/611352-st...ng-a-rusty-80-kz440d
'04 Suzuki DL650 K4 V Strom
17 Jul 2019 11:17
Hooray for a cheap and easy fix. Thankfully you found that before it became a catastrophic problem.
- Tvag06
17 Jul 2019 11:24 - 17 Jul 2019 16:18
Catastrophe is not desired. The nut was tight with a pin in it but not torqued to 100lbs. I've ventured out about 2 miles in town. Want to be sure she's 100% before I have all my trust in her. Ride, inspect... Ride, inspect... Ride, inspect...
Last edit: 17 Jul 2019 16:18 by Tvag06.
17 Jul 2019 14:08
You may still need wheel bearings.
- Tvag06
17 Jul 2019 16:18 - 17 Jul 2019 16:18SWest wrote: You may still need wheel bearings.
Thanks Steve. I'll keep an eye on it but I think it was the castle bolt. I just didn't tighten it down enough, not hardly.
Back to my carbs and the idling. I've got my air mixture screws turned out 2 turns and have not yet covered them with a welch cap. Right now I simply placed some of that poster putty over them to keep it sealed. Will adjusting the screws more than 2 turns provide a more rich fuel mix? Can this assist me in maintaining a steady idle at cold start and when warm? At what increments should I turn them out when testing? 1/4 turn? 1/2 turn?
As always thanks for your help.
17 Jul 2019 16:35 - 17 Jul 2019 16:36
Basic process is to warm up the engine and then adjust the pilot screws until you achieve the highest idle speed. Should be in the range of 2.5 turns open from lightly seated. If there isn't a whole lot of idle speed change with turning out the screws target 2.5 turns open. And yes, more open is richer.
Last edit: 17 Jul 2019 16:36 by Nessism.
The following user(s) said Thank You: Tvag06
- Tvag06
17 Jul 2019 16:49Nessism wrote: Basic process is to warm up the engine and then adjust the pilot screws until you achieve the highest idle speed. Should be in the range of 2.5 turns open from lightly seated. If there isn't a whole lot of idle speed change with turning out the screws target 2.5 turns open. And yes, more open is richer.
Great thanks. I'm at 2 turns out currently. When I achieve optimal performance, what do I plug the cavity with? Please don't say metal welch cap. There must be something less perminent right??
- JR
17 Jul 2019 17:33
You dont plug them or cover them.
US models came with metal cap over the screws to prevent adjustment - clean air laws ?. UK and Canada did not
- Tvag06
17 Jul 2019 17:54JR wrote: You dont plug them or cover them.
Even better. : ) Will adjust screws tonight after work.
17 Jul 2019 22:04
The factory cap was (as mentioned) to eliminate tampering, but it also keeps water out. Corrosion of those screws is a very real problem. I recommend packing the cavity with some heavy grease.
- Tvag06
18 Jul 2019 19:01 - 18 Jul 2019 19:02
Made the adjustments to the air mix screws. Settled on 2.5 turns out. Idle seems easier coming and needs no adjustment whether cold or hot. Thx guys.
Took a spin around the block without a helmet to see what I could hear. The chain sounds a bit loud. Going to increase the tension and lessen the play. From what I understand when pushing up on the chain from beneath it should only travel about an inch, correct?
Last edit: 18 Jul 2019 19:02 by Tvag06.
19 Jul 2019 05:14
Twenty five to thirty millimeters (1-1 1/4 inch) is pretty typical. Check your operator's or factory service manual to be sure. Also check for the correct procedure. Some require the rear wheel off the ground, while others require both wheels on the ground. I seem to remember one that required the rider to be on board. Some guys will argue that looser is better.
ymmv
ymmv
The following user(s) said Thank You: JR
