1982 GPz750 Phase II Making It more Unique.
  • scubaanders
  • scubaanders's Avatar
Re: 1982 GPz750 Phase II Making It more Unique.
06 Mar 2016 08:53
#714120
That's my boy! :cheer: :cheer:
Next! time we want the camera mounted on the fork looking the other way capturing some knee dragging action. :woohoo:
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
06 Mar 2016 11:26
#714138
scubaanders wrote: That's my boy! :cheer: :cheer:
/A
No knee dragging from me lol. I'd have to get some rear sets for that. Besides, I don't think I have it in me, esecially on the open road. I'm too old for that.
I really wasn't intending to lean in so much. The power and speed is now coming on so smoothly and quickly that it sneaks up on you. I don't know if you can catch it but i had to do a quick up shift from the right to left lean before I got my toe trapped between the road and the shifter. I need to get used to how easy it is now. The day before I ended up in some skids and locking up the rear in order to aviod over shooting corners or in one case ramming a car at a light. Just before i got home I was leaned over again with the back starting to slide coming into my neighborhood because i wasn't going to let a WRX get ahead of me. B)
I don't know if it is me or the bike but I didn't feel uncomfortable, no sphincter pucker at all. I'll credit the bike since I'm just a clumsy oaf.
  • GPzMOD750
07 Mar 2016 18:47 - 07 Mar 2016 18:48
#714392
I think I know what I missed. TIMING! I have it set right on the the marks right now but i know that if you tweak it a bit you can fine tune some issues. From what I can tell if you have low compression [check] and maybe rich [check] you should advance the timing slightly. What the hell! I'll give it whirl next time the weather cooperates.
Last edit: 07 Mar 2016 18:48 by GPzMOD750.
  • GPzMOD750
10 Mar 2016 19:08 - 10 Mar 2016 19:08
#714810
Well i played with the timing a little bit. I advanced it some but it didn't really make much of a difference. I then retarded it slightly my top end hasn't really changed, It does feel a bit ore peppy though and not as sluggish at speed, i was taking it easy since there was a lot of bacon frying around today. Nearly record temps even has the constabulary on their scoots (Troopers on Boxers and locals on Hogs). We're set to break a high temp record set in 1900 by at least 2°F tomorrow.
Mounting up to go to work tomorrow that's for sure!
Last edit: 10 Mar 2016 19:08 by GPzMOD750.
  • GPzMOD750
11 Mar 2016 06:26
#714866
Well, I made it to work. Only had one asshat cut me off coming out of a 7-eleven. I'd have footage but forgot to mount my camera.
The guy's lucky I didn't bust his side mirror as I went around.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Mar 2016 06:44
#714868
Bolt? What bolt. It's not even metric. :whistle:
  • GPzMOD750
11 Mar 2016 07:30
#714879
swest wrote: Bolt? What bolt. It's not even metric. :whistle:
That or my jacket has elbow armor. If I hadn't seen it coming, you know what I mean, he would have had an extra set of spare tires in the back. Either that or I would have become a hood ornament on a F350 coming up on my inside.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Mar 2016 07:40
#714880
Be careful of ones that drive the big trucks to compensate for his junk being so small. They're truly dangerous. :dry:
  • GPzMOD750
21 Mar 2016 18:57
#716644
Latest pic with some home{work}brew 30mm shock extenders.
  • GPzMOD750
09 Apr 2016 06:33
#720028
Nothing major to report, Still messing a little with the tuning. Changed the oil and went up to Brighton Ski Resort last weekend. I pulled the KZ750 badges off the side panels.
I have some goodies to put on. Some switch gear, quick twist throttle and a set of road lights. Going to wait until I get a fuse box from Creative Wiring Solutions now that he's no longer MIA.
OH YEAH! I have a set of ZRX shocks on the way!
  • GPzMOD750
23 Apr 2016 13:30
#722565
I finally received and installed the box, battery cables and flasher from Creative Wiring Solutions. Not a direct fit install but worked pretty good.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Apr 2016 14:12
#722573
Looks good. Did you solder the large cables?
