Peavylotus' Rebuild of the KZ Cafe
- peavylotus
- Movin on up
Re: Peavylotus' Rebuild of the KZ Cafe
09 Oct 2013 22:27650ed wrote: Do you know what the correct bore of the master cylinder should be for those calipers? If not, you should check since it may be different than the bore of the current master cylinder. Ed
Good catch, but thankfully the guy I bought him from asked me what master cylinder I was using and said he would set me up with one that moves a bit more fluid when I get the cash for it.
1980 KZ 1045 LTD Currently Workin' It Out
- peavylotus
- Movin on up
09 Oct 2013 22:51
I found a thread here on the topic of these exact brakes actually...nice here is a pick of one of them
I feel like no one is sticking with the stock disk...
Attachment KZ_6_pistons1.jpg not found
- peavylotus
- Movin on up
09 Oct 2013 22:52 - 09 Oct 2013 22:53
I found a thread
here
on the topic of these exact brakes actually...nice here is a pick of some of them
Attachment 2012-09-0112.28.35.jpg not found
Attachment 3301.jpg not found
Last edit: 09 Oct 2013 22:53 by peavylotus. Reason: link problems
- DoctoRot
10 Oct 2013 06:29peavylotus wrote: I found a thread here on the topic of these exact brakes actually...nice here is a pick of some of them
that's because those calipers don't float, the disks float. KZ calipers float and the disks are static. if you try to use a non-floating caliper, with a non-floating disk you will face catastrophe as there is almost no room for machining differences. It will cause braking problems or failure. get a set of floating rotors and your good.
The following user(s) said Thank You: bluezbike
- peavylotus
- Movin on up
10 Oct 2013 15:50
Well that sounds good to me I suppose, can't really argue with failing brakes... They had some pretty cool un-used disks up in lynnwood to choose from. Sucks I have to sell those rotors now though.
Do the police bike rear caliper fit on the 1980 rear? they are silver and have the Kawasaki logo which makes me want them to add some contrast to this all black bike. Black is my least favorite color/shade and this bike is covered in it!
- Stazi
10 Oct 2013 16:09
I can tell you that after riding a 2000 ZX9R for years and then moving to my 1982 KZ1000, the brakes on these old bike are TERRIBLE. Talk about having to squeeze for dear life...and you really need to use the rear brake more than you ever would on a modern bike otherwise you'll end up in the back seat of someones car.
Can't wait to be rid of them when I go to the R1 forks!
82 KZ1000-K2 LTD
- peavylotus
- Movin on up
10 Oct 2013 17:34
I haven't ridden a newer bike since I got the KZ and refuse to because then I'll want a new bike, my way of thinking is if I'm not happy with what I have than its best to wait until I am to ride something better. I'm sheltering myself until the project is done haha.
I agree though, the brake fade on the brakes were pretty unnerving at times but I have the vented disks and would imagine the solid ones being a little soft at high speeds, not sure though, its all speculation on my part.
Not to mention I did have water in my lines and low on fluid due to a reservoir leak, so really the whole brake system for me particularly was bad news bears.
Soooo dangerous.
Soooo dangerous.
- DoctoRot
11 Oct 2013 04:35Stazi wrote: I can tell you that after riding a 2000 ZX9R for years and then moving to my 1982 KZ1000, the brakes on these old bike are TERRIBLE. Talk about having to squeeze for dear life...and you really need to use the rear brake more than you ever would on a modern bike otherwise you'll end up in the back seat of someones car.
I once saw a short article on correct braking techniques in a bike magazine. it said to use only 1-2 fingers on the brake lever as having more fingers around the handlebar gives you better stability. I remember thinking, "I would end up in the back of a bus if i tried to do that on the KZ!"
- Stazi
11 Oct 2013 10:27DoctoRot wrote:Stazi wrote: I can tell you that after riding a 2000 ZX9R for years and then moving to my 1982 KZ1000, the brakes on these old bike are TERRIBLE. Talk about having to squeeze for dear life...and you really need to use the rear brake more than you ever would on a modern bike otherwise you'll end up in the back seat of someones car.
No doubt! I don't you could ever do a stoppie on a KZ even if you tried to squeeze the bejesus out of the front brake. The brakes are woeful. LOL
82 KZ1000-K2 LTD
- baldy110
11 Oct 2013 11:53 - 11 Oct 2013 11:55
Really guys, the brakes on my 78 KZ650 and ELR clone are fantastic and they are the stock ones. I run sintered pads which help but even the stock pads were good. I have ridden modern bikes and their brakes are better but I wouldn't call the brakes on the older KZ's bad. I ride with a bunch of younger guys on new machines and I am still out front in the twisties even with my old brakes and suspension.
Last edit: 11 Oct 2013 11:55 by baldy110.
11 Oct 2013 12:14
"As new" front brakes on both Z1 (single disc) and KZ900B1 LTD (dual discs) will squall the front tire on clean dry road surface when applied with a firm squeeze -- Godzilla strength not required.
Squalling is enough braking power, beyond which wheel lock-up is undesirable, and dangerous.
Imo, stoppies abilities are relegated to stunting, and without practical benefit.
11 Oct 2013 13:50 - 11 Oct 2013 13:56
I suppose any brake system would work poorly if you let the system get contaminated with water and air. The stock brakes on my KZ650-C1 work great! Of course, I maintain them by changing the brake fluid every 2 years, and I keep sticky tires on my bike. Will it pull stoppies? No; and I'm glad it doesn't! It simply stops the motorcycle quickly in a controlled fashion. I'll leave the stunts to highly trained professional riders with unique riding skill like these:
And just in case any newbies believe the damage is always limited to the bike:
Last edit: 11 Oct 2013 13:56 by 650ed.
