Stu Pidasole's Build
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: Joe's '78 kz1000 build
07 Jan 2011 08:04
#420516
531blackbanshee wrote:
next up is giving them a nice place to dwell in the upper triple clamp.that will require the mill and the boring head to called on for duty:ohmy: .
the stem is bigger than the hole(ideal marriage?:silly: )and will require boring the triple to be a slip fit for the stem.
:woohoo: :laugh:
1978 KZ1000A2
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
07 Jan 2011 08:11
#420517
joe,here is the bottom of the zx stem(steel)with the kz stem(steel) pressed in to it.
larry chose to use a set screw to secure the two together,which has the advantage of making the stem removable.
in the past i have welded the two together for a permanent fix.you would have to have it machined to separate it.
the zx stem has a snap ring on the bottom od of the stem that locks against a step in the bottom of the lower triple preventing it from being pulled through the triple when tightend.
the kz stem has a step around the bottom od of the stem below where the lower race rides.
so when the two are locked together the snap ring prevents it coming up and the step prevents it going down.
my question to you joe is do you want it welded together or set screwed sir :huh: ?
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 08:13
#420519
glad to make your day man.
i can't see any vids joe,sorry.
  • kz1k
07 Jan 2011 08:30
#420523
i would think welding it would be easier. whatever you wanna do Leon, i have faith in ya dude. as for the video, your not missing much...lol
looks great!
1978 KZ1000A2
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 08:35 - 07 Jan 2011 08:36
#420526
joe,
your a welder,
i'm a welder.
the older i get,sometimes,
i would rather weld than screw :woohoo: :laugh: :silly: :P
weld it is,thanks for the input.
Last edit: 07 Jan 2011 08:36 by 531blackbanshee.
  • kz1k
07 Jan 2011 09:08 - 07 Jan 2011 09:23
#420534
hey guys, i just notices the rear tire is not centered to the rear of the frame. the swing arm is where it need to be. i guess i need to move the frame? i really wanna keep the frame where it is.....time to go out there and check my options....any ideas?
i took a measurement its a 1/2" diff.
1978 KZ1000A2
Last edit: 07 Jan 2011 09:23 by kz1k.
  • larrycavan
  • larrycavan's Avatar
07 Jan 2011 09:21 - 07 Jan 2011 09:26
#420536
Last edit: 07 Jan 2011 09:26 by larrycavan.
  • kz1k
07 Jan 2011 09:31
#420538
larrycavan wrote:
so larry, if i buy parts from the bike i have been buying, i should get the front master cylinder, but buy a lever from a 95 bike? im getting lost confused now.....
i was planning on buying the 2000 zx7r front brake m/c and lever/lines, and resevior.
1978 KZ1000A2
  • porchev914
  • porchev914's Avatar
07 Jan 2011 09:32
#420539
It would take ALOT of fabrication work and time to center the wheel in the frame. If it makes you feel any better, my wheel is 1/4" off of center, but that was a compromise between an almost centered rear wheel and 1" of sprocket offset. I am suprised that your rear wheel is that far to the left though....I'm sure Larry will chime in if his was the same.
FRANKEN Z!
  • larrycavan
07 Jan 2011 09:34
#420540
:woohoo: :laugh:
I milled down the top clamp on the bottom, where it rests against the bearing adjusters. Reason being ride height. I grabbed 5mm where ever I could get it ;)
Same with fitting up the swingarm. I felt it was too wide to try to take all the material from 2 spots so it was 5mm here, 5mm there...another 5 here..another 5 there....
  • z650c3
  • z650c3's Avatar
07 Jan 2011 09:37
#420542
kz1k wrote:
be easy with her, its her first time...lots of foreplay and lube...lol
super sweet Leon. looks great.:)
Shock , horror , scandal , report !!!!!!!!!!!!!!!!!!!!!!
Very dodgy wording here kz1k :lol:
c3
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
  • larrycavan
07 Jan 2011 09:37 - 07 Jan 2011 09:41
#420543
Something isn't right. Start looking at your wheel spacers.
This is not a great pic but here's mine when I was aligning things with a laser.
Last edit: 07 Jan 2011 09:41 by larrycavan.
