Stu Pidasole's Build
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: Joe's '78 kz1000 build
03 Jan 2011 10:29
#419857
caliper side....now that i know where my tire will sit, i am just waiting on my pivot sleeve to get the rear perminatly nestled in.
1978 KZ1000A2
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
03 Jan 2011 11:30
#419863
glad your parts showed up.
keep swingin your gettin there,
  • kz1k
03 Jan 2011 11:30
#419864
how much of the weld do i grind? omr's thread stated he ground too much. and whats the best way to get it pushed out?
1978 KZ1000A2
  • kz1k
03 Jan 2011 11:32
#419865
heres another shot.
1978 KZ1000A2
  • 531blackbanshee
  • Vendor
  • Vendor
03 Jan 2011 11:37 - 03 Jan 2011 11:37
#419866
smack it with a soft faced hammer and look for a crack to appear around where they are joined.it usually turns blue when it starts getting close.i am fortunate i just chuck them in the lathe and just cut the weld out and bevel at the same time.:P
Last edit: 03 Jan 2011 11:37 by 531blackbanshee.
  • kz1k
03 Jan 2011 11:55 - 03 Jan 2011 11:57
#419871
yuppers, and 3 lb sledge did it. :laugh: now...on the bucket do i need the 2 parts on the left....the rings? and now whats next?
1978 KZ1000A2
Last edit: 03 Jan 2011 11:57 by kz1k.
  • DoubleDub
  • DoubleDub's Avatar
03 Jan 2011 12:41
#419881
Those look like races for loose ball bearings.
You're using the stock neck/stem, right? If so you will need the other half of the tapered roller bearings (look like metal rings that fit the bearings on the stem).
  • kz1k
03 Jan 2011 12:51
#419885
this other tapered bearing?
1978 KZ1000A2
  • DoubleDub
03 Jan 2011 13:59 - 03 Jan 2011 14:01
#419903
Part of it. There are two pieces to a tapered bearing...the bearing and the ring.
There is also a grease seal you will need - maybe that's what those two pieces are, hard for me to tell.
Tapered bearing with seal kit:
www.z1enterprises.com/detail.aspx?ID=2780
Image courtesy of Z1Enterprises.com.
Last edit: 03 Jan 2011 14:01 by DoubleDub.
  • kz1k
03 Jan 2011 14:34
#419910
looks like one is a seal, and the other piece is like a flat washer...hmmm.
1978 KZ1000A2
  • kz1k
03 Jan 2011 14:43
#419911
so, from what i got from omr's thread is i need to remove the stem from the zx triple (kawasaki shop?) and have a sleeve made to weld to the kz stem?
1978 KZ1000A2
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
03 Jan 2011 14:55
#419913
PM sent.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
