Stu Pidasole's Build
- trianglelaguna
Re: Joe's '78 kz1000 build
28 Dec 2010 13:44
later i'll post a pic of someone welding their own risers on...not as clean as larry's but all aluminum and nice finished example...sit up and beg bars
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- kz1k
- You Cant Fix Stupid!
28 Dec 2010 14:12
trianglelaguna wrote:
thanks for all the help craig. your a good friend.later i'll post a pic of someone welding their own risers on...not as clean as larry's but all aluminum and nice finished example...sit up and beg bars
1978 KZ1000A2
- porchev914
28 Dec 2010 15:42
DutchZ's thread is a good one, he built a killer mean, old school lookin Kz. It's worth it to read his thread. I believe you have already read my project and swingarm threads Joe, but a friendly bump from Craig doesn't hurt.
He makes a good point though - you should always have a good reason for the mod you're doing. Nothing says amature hack faster than changing something that doesn't need to be changed, for no other reason than to change it.......But that doesn't apply to me or my carbon fiber parts. Do as I say, not as I do......
FRANKEN Z!
- Brown Bear
28 Dec 2010 15:57
just a quick nose, noticed ppl talk about painting teh frame, a etch primer is fine after you sand the frame etc. evevn hammerit NO.1 rust killer and primer in one. ment toi be good stuff and if ok on bare metal. comes up smooths im told. painted or sprayed.
- kz1k
28 Dec 2010 16:22 - 28 Dec 2010 16:23
Brown Bear wrote:
adam, but i am a amature!
its $15 bucks for a 6061 T6 1" OD .0624 ID tubing at 12" plus whatever loctite costs.......not too bad for my swingarm mod cost on a sleeve.
its about time people got back on the site!!!!:laugh:
wrong thread brother.:dry:just a quick nose, noticed ppl talk about painting teh frame, a etch primer is fine after you sand the frame etc. evevn hammerit NO.1 rust killer and primer in one. ment toi be good stuff and if ok on bare metal. comes up smooths im told. painted or sprayed.
1978 KZ1000A2
Last edit: 28 Dec 2010 16:23 by kz1k.
- porchev914
28 Dec 2010 18:24
kz1k wrote:
So the wall thickness is .9376"? damn, thats some thick walled "tubing" :laugh:
Brown Bear wrote:wrong thread brother.:dry:just a quick nose, noticed ppl talk about painting teh frame, a etch primer is fine after you sand the frame etc. evevn hammerit NO.1 rust killer and primer in one. ment toi be good stuff and if ok on bare metal. comes up smooths im told. painted or sprayed.
FRANKEN Z!
- kz1k
28 Dec 2010 20:07 - 28 Dec 2010 20:08
porchev914 wrote:
if you must know......
OD 1"
Wall 0.1875"
ID tolerances are by reference only
Tolerances can only be guaranteed for OD and Wall
ID 0.624"
Tolerances
Dim. Name Plus Minus
OD 0.004" 0.004"
Wall 0.006" 0.006"
ID 0.006" 0.006"
Technical Information
This material meets the following specs:
WW-T 700/6
AMS 4082
ASTM B210
Mechanical Properties
Property Value
Elongation
% in 2 inches 12
Modulus of Elasticity
KSI x 10^3 10
Ultimate
KSI 42
Ultimate shear strength
KSI 27
Yield
KSI 37
Please note that this data is to be used ONLY FOR REFERENCE, NOT FOR DESIGN, and by using it, you agree that any decisions you make regarding materials for your project are at your own discretion.
Chemistry information for alloy 6061 Aluminum
Element Percentage
Al Remainder
Cr 0.04 - 0.35
Cu 0.15 - 0.4
Fe 0.7 max
Mg 0.8 - 1.2
Mn 0.15 max
Si 0.4 - 0.8
Ti 0.15 max
Zn 0.25 max
:laugh:
kz1k wrote:Brown Bear wrote:wrong thread brother.:dry:just a quick nose, noticed ppl talk about painting teh frame, a etch primer is fine after you sand the frame etc. evevn hammerit NO.1 rust killer and primer in one. ment toi be good stuff and if ok on bare metal. comes up smooths im told. painted or sprayed.
OD 1"
Wall 0.1875"
ID 0.624"
Tolerances
OD 0.004" 0.004"
Wall 0.006" 0.006"
ID 0.006" 0.006"
WW-T 700/6
AMS 4082
ASTM B210
Property Value
Elongation
% in 2 inches 12
KSI x 10^3 10
Ultimate
KSI 42
KSI 27
Yield
KSI 37
Element Percentage
Al Remainder
Cr 0.04 - 0.35
Cu 0.15 - 0.4
Fe 0.7 max
Mg 0.8 - 1.2
Mn 0.15 max
Si 0.4 - 0.8
Ti 0.15 max
Zn 0.25 max
:laugh:
1978 KZ1000A2
Last edit: 28 Dec 2010 20:08 by kz1k.
- porchev914
28 Dec 2010 20:18
But do you see the typo you made in your post about the I.D. being .0624", instead of .624"? Thats what I was busting your balls on. Now I'm just gonna tease you for copying and pasting a bunch of crap that doesn't matter
For example, the Cp1, grade 4 titanium I have for a muffler has the following properties and Applications:
Airframe components, cryogenic vessels, heat exchangers, CPI equipment, condenser tubing, pickling baskets.
Composition nominal wt. %
C 0.10 max, Fe 0.20 max, H 0.015 max, N 0.03 max, O 0.18 max, Ti rem
Specifications
MIL-T-81556.
ASTM B 265, 33, 338: ASTM F 67.
Density lb/in3 (gcm3) 0.163 (4.51)
Metallurgical Condition 1,300°F anneal
Tensile Strength ksi (MPa) 35 (241)
0.2% Yield Strength ksi (MPa) 25 (172)
Elongation % 24
Reduction in Area % 30
Hardness 70 HRB
Specifications
MIL-T-81556.
Elongation % 24
Hardness 70 HRB
FRANKEN Z!
- racer54
28 Dec 2010 20:25 - 28 Dec 2010 20:26
Huh? Sorry guys...you must be lost...this forum is for motorcycle enthusiasts. Rocket scientists have their own forum....I think!:blink:
:laugh:
Last edit: 28 Dec 2010 20:26 by racer54.
- porchev914
28 Dec 2010 20:29
"Joe the Rocket Scientist".....hmmmmmmm, how about just "Joe Rocket". You already have a line of riding gear.....I'd go with that nickname Joe!
FRANKEN Z!
- testarossa
28 Dec 2010 20:42
porchev914 wrote:
Well, he does live in Florida, and it's well known that he likes to get, uh, "high."
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- kz1k
28 Dec 2010 20:44
1978 KZ1000A2
