Stu Pidasole's Build
  • larrycavan
  • larrycavan's Avatar
Re: Joe's '78 kz1000 build
03 Jan 2011 15:24
#419916
KZ stem gets pressed into the cut of 7 stem.
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
03 Jan 2011 15:41
#419920
i am guessing the zx stem comes out of the bottom of the zx triple? not sure how to get it out without damaging the triple.
1978 KZ1000A2
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
03 Jan 2011 16:26
#419926
Were you able to get a hold of Brian?
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • kz1k
03 Jan 2011 16:30
#419927
-KR
negative
1978 KZ1000A2
  • kz1k
03 Jan 2011 16:37
#419928
everything on my rear lined up today exept for this one spacer on the rotor side. the spacer on the sprocket side slid in flush into the wheel. the spacer on the brake side went in about 3/8" and then about 3/4" shows. the caliper housing is pressing againt it and the swing arm was a snug fit when i fit it up. here is a picture...does this look right? wheres larry when ya need em.:laugh:
1978 KZ1000A2
  • larrycavan
03 Jan 2011 16:53 - 03 Jan 2011 16:55
#419931
Working from memory..... the collar on the rotor side doesn't go into the seal very far & fitting the wheel up inside the arm was a nice snug fit.
If the brake caliper is centered on the rotor, tighten the axle nut while spinning the wheel. It should tighten up and the wheel should spin nice & free Joe :)
What are you using for foot pegs and rear master cyl?
Last edit: 03 Jan 2011 16:55 by larrycavan.
  • larrycavan
03 Jan 2011 16:59 - 03 Jan 2011 17:06
#419932
There's a snap ring on the bottom of it that has to come off first. You mighty not be able to easily see it but it should be there. Mine had one.
I put mine in a lathe and cut the aluminum back away from the snap ring a little, then pushed it down from the top enough to get the ring off, then pushed it out. As I recall I pushed it from the bottom up through after removing the snap ring.
Once it was out, I figured the length I needed & cut the stem off. Then press the KZ stem into the stub of the 7 stem.
After the stem was pressed back into the lower clamp, I drilled to holes for set screws to take the place of the snap rings, threaded them and loctited allen set screws into them.
I heated the clamp prior to pressing the stem back in. It's one tight mutha :)
Last edit: 03 Jan 2011 17:06 by larrycavan.
  • kz1k
03 Jan 2011 17:17
#419937
thanks for the reassurance larry. i think im ganna go with the zx7 foot pegs and MC. that should be the easiest route...no?
also i am sending my stem and triples to Leon, (blackbanshee) to machine and such. this way i know the front end doesnt come off while riding...:laugh:
1978 KZ1000A2
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
04 Jan 2011 05:57
#420012
i will get the stem swap done and headed back to florida as soon as i get my hot little hands on it.
:laugh:
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
04 Jan 2011 07:33
#420021
:laugh:
Haaaaa! If only I could get my hands to shrink that small when I'm working on my bike! ...and since I'm married having women gage me by my "hand size" wouldn't be an issue.
:woohoo:
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
  • porchev914
  • porchev914's Avatar
04 Jan 2011 16:54
#420075
That was a wise decision Joe. It takes a smart man to know when to farm out work.
FRANKEN Z!
  • kz1k
04 Jan 2011 19:26
#420095
thanks adam. hey Leon the parts went out this morning.
i got the sleeve today and got it in the zx sleeve. tomm after fishing i will install the linger pivot bolt and snug her up.
1978 KZ1000A2
