Stu Pidasole's Build
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Joe's '78 kz1000 build
07 Jan 2011 07:33
#420501
now i am going to fill your thread with pictures :laugh: .
here are your trees after i recieved them.
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
07 Jan 2011 07:34
#420502
531blackbanshee wrote:
you need the master and the slave.it will take some minor modification to the stock cover,but you can make it work.
not sure what the slave is.....test had me under the impression i would have to buy a $400 kit.....hmmmmm.:dry: now im really confused...lol:blink: :laugh:
1978 KZ1000A2
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 07:36
#420503
a hydraulic clutch consist of a master cylinder mounted to the handlebar and operated buy a lever connected with a line to the slave cylinder down on the clutch cover that pushes the clutch pushrod in to release the clutch.
you savvy?
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 07:43
#420505
i chucked the lower zx triple in the lathe and used some emery cloth on my finger to polish up inside the zx stem for an accurate measurement.well with the od of the kz stem and id of the zx stem polished there was .0015 press fit.:) no isn't that special :laugh: .
so i put the zx tree in the vise and broke out the porta band(i love that thing:silly: )and sawed the stem off.
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 07:44 - 07 Jan 2011 07:45
#420506
carnage,and the tool that caused it.
the zx stem after the separation.
Last edit: 07 Jan 2011 07:45 by 531blackbanshee.
  • kz1k
07 Jan 2011 07:44 - 07 Jan 2011 07:47
#420507
you savvy?
yeah that make sense. i just wanna find out if its worth going that route? pros and cons?
also is this what ill need for my steering stem?.... www.z1enterprises.com/detail.aspx?ID=2780
wow leon, seeing photos of your work on my parts is the coolest. what a trip. you da man!
1978 KZ1000A2
Last edit: 07 Jan 2011 07:47 by kz1k.
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 07:51
#420509
affirmative sir!
thats you scooby doo!
hydraulic clutch usually means less effort on the lever is needed.it also has less"feel",not so big a deal on the street.i raced on dirt tracks and am used to slipping a clutch to manipulate my engines rpm,so i don't like hydraulic clutches and preffer the "feel" of a cable clutch.
you have to decide whatcha like. :P
here we have the kz stem ready for marriage to the zx triple.the honorable 531blackbanshee will be officiating the ceremony,haha.
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 07:53
#420510
you sir(kz stem)
may kiss the bride(zx triple)
may i present to you the happy couple,
  • kz1k
07 Jan 2011 07:54 - 07 Jan 2011 07:58
#420511
be easy with her, its her first time...lots of foreplay and lube...lol
super sweet Leon. looks great.:)
1978 KZ1000A2
Last edit: 07 Jan 2011 07:58 by kz1k.
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 07:57
#420512
i would like to present the happy couple.
  • 531blackbanshee
  • Vendor
  • Vendor
07 Jan 2011 08:00
#420514
next up is giving them a nice place to dwell in the upper triple clamp.that will require the mill and the boring head to called on for duty:ohmy: .
the stem is bigger than the hole(ideal marriage?:silly: )and will require boring the triple to be a slip fit for the stem.
  • kz1k
07 Jan 2011 08:02
#420515
well my day is made. looks super!!! ill be ordering the bearing/seal kit this evening from z1e.
1978 KZ1000A2
