Stu Pidasole's Build
  • larrycavan
  • larrycavan's Avatar
Re: Joe's '78 kz1000 build
18 Dec 2010 05:09 - 18 Dec 2010 05:21
#417538
Can you spell ENTHUSIASM boys and girls :laugh:
Last edit: 18 Dec 2010 05:21 by larrycavan.
  • larrycavan
18 Dec 2010 05:23 - 18 Dec 2010 05:25
#417539
:) Just funnin` you guys... don't get your shorts in a knot
Last edit: 18 Dec 2010 05:25 by larrycavan.
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
18 Dec 2010 06:25
#417551
larr.. at least gimme a chance to put my girls pic on here first.....oops...here she comes...gatta go!
1978 KZ1000A2
  • kz1k
18 Dec 2010 20:38
#417664
sorry about the pics again...batteries tomm. im just getting my cases settled in with the sprocket installed before any mods happen.
the guy i ordered the swringarm and mono shock from recieved my payment finally and will be shipping out monday.
1978 KZ1000A2
  • kz1k
20 Dec 2010 00:58 - 20 Dec 2010 01:00
#417847
hey guys, i have never put a kz back together. i just slapped my cases together to install my output shaft. from the case to the center of the sprocket i have 1". does that sound right? thats without the sprocket housing.
1978 KZ1000A2
Last edit: 20 Dec 2010 01:00 by kz1k.
  • kz1k
21 Dec 2010 21:50
#418166
happy holidays guys!!!!
1978 KZ1000A2
  • z1kzonly
  • z1kzonly's Avatar
21 Dec 2010 22:18
#418168
You are gonna need this set up.
A plate from member, Ben "Irish will"
And a 5/8 offset sprocket with snout for 52mm x 25mm bearing. This is a PBI 17th for 530 chain.
Another $200.
The 2 metal bung weld to the frame when it is lined up.
I have a freind who is raking a frame now.
We'll get this mounted after the Holidays
  • kz1k
22 Dec 2010 03:04
#418177
Another $200.
i was unaware i would need this setup.
1978 KZ1000A2
  • z1kzonly
  • z1kzonly's Avatar
22 Dec 2010 04:29
#418181
Wider the tire, you need to go offset. If your just going to cruise it and not hot rod it.
You could get away with just an offset sprocket, and grind the original sprocket cover away for chain clearence.
  • kz1k
22 Dec 2010 04:38
#418184
i planned on the 5/8" sprocket.
1978 KZ1000A2
  • kz1k
23 Dec 2010 08:35
#418290
today is a good day. i just baught zx7r forks, triples, front axle, rim and tire, front rotors, rear sprocket hub, spacers, and cush for $470 locally.
1978 KZ1000A2
  • kz1k
23 Dec 2010 10:39 - 23 Dec 2010 10:41
#418297
whoohoo and my swingarm and shock showed up today. thanks santa!!!!:P
1978 KZ1000A2
Last edit: 23 Dec 2010 10:41 by kz1k.
