Stu Pidasole's Build
- kz1k
- You Cant Fix Stupid!
Re: Joe's '78 kz1000 build
12 Dec 2010 13:38
well im just cleaning my pistons. maybe karma will come through and my pistons and bore will be in the manual guidlines....
1978 KZ1000A2
- kz1k
12 Dec 2010 13:40
after engine carb cleaner, razor knife, and a brass brush. each piston is labeled and will be going with the block to the machinist tommorow for measuring.
1978 KZ1000A2
- kz1k
12 Dec 2010 16:25
1978 KZ1000A2
13 Dec 2010 06:57
that should get them there.
powder looks nice!all that and a dime sack,haha!
- porchev914
13 Dec 2010 08:18
Joe, did you ever check to see if you still had 900 pistons, or if a previous owner had bored out that 900 cylinder?
FRANKEN Z!
- kz1k
14 Dec 2010 08:41
porchev914 wrote:
my cylinders and pistons are at blockhead machining here is stuart fl for a tolerance check. fingers crossed. ill have #'s for you guys.Joe, did you ever check to see if you still had 900 pistons, or if a previous owner had bored out that 900 cylinder?
1978 KZ1000A2
- kz1k
14 Dec 2010 16:22
well it looks like a piston/bore job has come into play. better now, than later.
1978 KZ1000A2
- porchev914
14 Dec 2010 20:07
My humble is to focus on working with what you have. Get some gaskets and any other parts you need to assemble the bottom end and get it together. you have a gorgeous frame that is begging to be put back together. Now is the time to focus on cleaning up/painting all the parts that are going to bolt on to that black beauty
While you are doing all that (and it's ALOT), keep your eyes peeled for a lightly used cylinder and piston kit. Either from a member here, craigslist, pitstop..... wherever. Staying busy with the details will help you wait until a great deal on the cylinder and pistons turns up.
FRANKEN Z!
- kz1k
15 Dec 2010 09:32
yes, i am going backwards, but i really want a larger rear tire. i am going with a zx7r 96-03 rear end. the arm and shock are on thier way. time to pick out a rear tire.
1978 KZ1000A2
- kz1k
15 Dec 2010 09:54
1978 KZ1000A2
- kz1k
15 Dec 2010 09:55
1978 KZ1000A2
15 Dec 2010 13:10
well there you go!
make sure and verify axle size before you buy a wheel.
