Nelson's KZ1000 Fighter? build
- wireman
Re: Nelson's KZ1000 Fighter? build
16 Feb 2013 02:25Attachment popcorn_2011-05-24_2013-02-16.jpg not found
- Nelson
25 Feb 2013 03:00 - 25 Feb 2013 03:27
Got the front brake all assembled and bled. It's got a good feel now. Someone was asking about this ealrier so here's pic of one of the SV650 calipers. You can see the aluminum plate I made for it. I did have to carefully grind down the boss's on the inside of the fork legs to make this work, so it wasn't quite as simple as just making the plates.
Attachment FbrakeAssembled.jpg not found
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Last edit: 25 Feb 2013 03:27 by Nelson.
- Nelson
25 Feb 2013 03:05
I don't like this sprocket. Look at the chamfering by the splines. It significantly reduces the engagement area between the sprocket and the shaft. The shaft barely sticks out far enough as it is, this is not cool. Crappy Emgo!! I think I bought it from Z1 Enterprises. I wonder if I could return it after having it a year or so... :pinch:
The old sprocket I took off did not have the chamfer. I think I need a diff brand. Any suggestions?
Attachment emgosprocket.jpg not found
- Nelson
25 Feb 2013 03:10 - 25 Feb 2013 03:11
I put this stuff on today. Noticed the large starter gear does not spin freely. It has a bit of drag when I push down as shown. Before tightening the flywheel bolt it would spin free, but as I tightened it the gear started to drag. Is that the rubber damper pushing against it?
I took it apart and oiled everything then reassembled and still the same. I don't know if a bit of drag is normal. This is assembled with all the old parts I took off, there are no new parts and nothing different. Same old rubber damper.
Ideas?? :huh:
Ideas?? :huh:
Attachment startergear.jpg not found
Last edit: 25 Feb 2013 03:11 by Nelson.
25 Feb 2013 12:32
i wouldn't sweat the chamfer on the sprocket.
i am of no help on your starter gear drag tho,
sorry.
sorry.
- Ruff
25 Feb 2013 12:52
I believe some drag is necessary.
Thank you,
Ruff
Ruff
- Zedone
25 Feb 2013 16:46
Nice looking work Nelson, Kawasaki made 3 different size rubber starter gear dampeners, if you feel you have too much drag you most likely need the next larger one. You can not buy these dampeners (to my knowledge anyway) so you will need to find them used. I was in the same boat over the winter grabbed one off of a spare motor I had. I had the part numbers writting down somewhere and can find them if you need them. This is one area of the Z1 KZ motor I thought could have been designed better as its a pain to get dialed in properly.
Doug
Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- Nelson
25 Feb 2013 18:59
yeah I tried to buy one a while back and could not find them. Wouldn't I need the next SMALLER one to create more clearance?
Odd that these are all the same parts I took off it... Maybe it had this drag before and I didnt' know it. Seems like too much tho. I"m afraid it will get hot and melt the edge of the damper.
- Nelson
25 Feb 2013 19:02
I wonder if too much drag could cause the starter to turn...
- Nelson
25 Feb 2013 19:05
regarding the sprocket - I've seen severely damaged countershaft splines on many dirt bikes. Even a little KDX200. This is not cool for a 1000. The KZ shaft barely sticks out far enough as it is.
- zed1015
25 Feb 2013 20:23Nelson wrote: I wonder if too much drag could cause the starter to turn...
Yes! if there is too much drag it will prevent the starter clutch from freewheeling and cause the engine to spin the starter.
I would leave it for now and see what happens when you run the bike as it may be ok after all.
You can buy the dampers from kawasaki and places like z-power etc.
If it does drag too much and you can't find a supplier then you can reduce the thickness by carefull lapping of the rubber edge on some fine wet and dry used wet.
You need to take it easy and keep test fitting the damper until you get the desired fit.
The following user(s) said Thank You: Nelson
- Nelson
25 Feb 2013 21:17
How would I know if there is too much drag while it is running? Can't see anything...
